Home > Technical > Brake Servo failure - PO17 re-occured
MattMatt
United Kingdom 2007 Range Rover Sport TDV6 HSE Zambezi Silver
The RRS I've just bought (from a friend who did pre-warn me there might be a problem) has this oil in the servo failure problem that was subject to a recall some years ago. The car had the recall done in 2009 according to the Stealer and it is going in this afternoon to have it checked out to make certain it is the same symptom
Where do I stand if this is the same problem as the recall was meant to rectify. I wouldn't expect it to happen again if the job had been done right first time round. Do I press for it to be done again?
Post #467038 Thu Jul 09 2015 10:34am
MattMatt
Update
Oil in the Servo. £1000 + VAT to fix it. Gutted. Emailed LR to see if they will foot some of the cost. Not holding out much hope as it's been six years since the recall was done
Post #467057 Thu Jul 09 2015 2:59pm
Stuart
Isn't a used servo a better option? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #467075 Thu Jul 09 2015 9:22pm
Bodsy
Site Sponsor
Push LR, I would be very surprised if they don't cover this major safety issue. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #467080 Thu Jul 09 2015 9:50pm
RRS PIMP
Oil in servo
I had the same issue last year, even though I took my car in for the recall in 2009.
Indie I took it to said the valve the main dealer fitted to the pipe from the servo was fitted the wrong way round. He also mentioned when they go in for the recall the damage may have already been done, but the technicians were only fitting the modified valve / pipe and didn't really check for oil that was already in the servo.
He replaced the servo with a new original part, cost around £65. There's one on EBay for sale now.
Post #467172 Fri Jul 10 2015 6:51pm
MattMatt
Thanks for the feedback - I've got a case number from LR now so will see what they say first
Post #467388 Mon Jul 13 2015 11:26am
MattMatt
Reply from LR
"a full investigation will have to be undertaken to determine if the concern on your vehicle is indeed related to the P017 recall. If the concern is related then Jaguar Land Rover will liaise with the retailer and cover the cost of repair."
We wait and see what the outcome may be
Post #467826 Fri Jul 17 2015 12:50pm
MattMatt
Problem Fixed!
Bow down Hats off JLR and Grange (formerly T H White) near Swindon.
After a diagnostic they found oil in the servo and vacuum pipes so replaced the lot. The RRS came back yesterday with:
    new vacuum hose
    new vacuum pump
    new brake booster (servo)
all done FOC under the PO17 recall that had already been done back in 2009 but obviously not to a great standard.
They even gave me an Evoque as a courtesy for a few days.
Can't fault them (Oh and they put on a new fixed tow bar as well!)
(Admin - can you add this to the Recall thread so it's all in one place?)
Post #468795 Tue Jul 28 2015 7:37am
stricko
2006 Range Rover Sport TDV6 HSE Zermatt Silver
Ive just noticed this on mine over the last few days.
I had also noticed the 'running water' sound mentioned in another recent thread.
A bit worrying as we are off on a long journey shortly.
I am waiting for a call back from the local LR dealers to see if its been done on mine already.
Post #468807 Tue Jul 28 2015 8:46am
stricko
update:
The dealers called back to say that the PO17 recall had been done on mine in November 2011.
I have it booked in tomorrow with the local indie who is going to check if its the same symptoms. I will then know if I have an argument on my hands with LR to get it fixed a second time.
Post #468833 Tue Jul 28 2015 12:57pm
stricko
Hi
The car is in the Dealers at the moment and they have just called back to say there is oil in the booster and master cylinder etc. (which I had verified by an indie the other day)
I explained to him that I am sure this is a recurrence of the PO17 recall and he is now checking it with the technician.
Does anyone know if there is any other way that oil could get into the booster and master cylinder other than the fault under the PO17 recall?
It would be good to know so that I am well prepared for the discussion with LR to pay for it.
Thanks
David
Post #469428 Tue Aug 04 2015 1:57pm
Bodsy
Site Sponsor
There is no other way for oil to get there, it's their failure to fix it first time..... Bodsys Brake Bible
See it HERE
Post #469449 Tue Aug 04 2015 5:35pm
MattMatt
Like Bodsy said - the only way oil can get to the servo is through the vacuum pump and up the vacuum tube into the Servo.
LR didn't quibble about the issue with me. The dealer tested the servo and found it had reduced functionality (faulty) due to oil being present. As mentioned LR now recommend the whole vacuum pump is replaced (which is £575 alone) together with the pipe and Servo so well worth pursuing it
Post #469544 Wed Aug 05 2015 8:43am
stricko
Thanks Bodsy and Matt
The dealers have now agreed that it is the PO17 issue and are speaking to LR to get it sorted. They were happy to charge me for the work before I pushed the issue with them.
Post #469562 Wed Aug 05 2015 12:26pm
stricko
Final update - I now have the car back with all new parts courtesy of LR.
Thumbs Up to Harwoods Brighton for taking it up with LR and getting it sorted.
Post #470085 Tue Aug 11 2015 9:41am
