Home > Tips & Tricks > Access Height - Set to Automatically work?
Page 2 of 3 <123>
Paddi
Sorry Dr Rob but that is one of those myths that somehow has been often quoted as fact on the forum..
See the post by our resident electronics guru Robbie in this thread:
http://www.rrsport.co.uk/forum/post445842.html#445842 2008 MY Java Black TDV8 HSE
Post #465016 Thu Jun 18 2015 4:37pm
DrRob
OK Razz Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #465029 Thu Jun 18 2015 5:28pm
Camelrock
Just a thought, won't constantly using access mode every time you stop increase wear in the sus bushes ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #465032 Thu Jun 18 2015 5:51pm
idrabble
Australia
@camelrock - probably no more than the suspension moving up and down thousands of times every time you drive the car!!!!!!
Post #465068 Fri Jun 19 2015 1:14am
garrycol
Australia
I would be more worried about unnecessary wear in the air compressor. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #465069 Fri Jun 19 2015 2:47am
idrabble
Australia
I don't see that either. My compressor switches on at start up whether I have lowered to access height or remained at normal.
I'm also a great believer in using machinery is less detrimental to it's life span than not.
Post #465070 Fri Jun 19 2015 3:02am
garrycol
Australia
Yes but on start and when the car is running the air compressor is just topping the tank up - when you lower the vehicle each time you get out, you are wasting air that has to be pumped back in on next start - much more effort than just topping up. Lowering every time you stop the car or let someone in or out substantially increases wear on the compressor - well not so much wear on the compressor directly, but increased clogging of the desiccant which in turn causes heat in the compressor and wear.
The more the compressor is used the more moisture is being sucked into the desiccant. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #465071 Fri Jun 19 2015 3:57am
idrabble
Australia
I don't think anyone is right or wrong here, but I would personally rather use all the functionality of my car than not and worry about a compressor replacement as or if required.
Plus my wife is a short-arse and wouldn't be able to get in otherwise Smile
Post #465073 Fri Jun 19 2015 5:05am
DrRob
I know........! Use it once in a while to keep things flowing and working Thumbs Up
Just like aircon in a car - use it regularly to keep the seals lubricated.... Visitor from fullfatrr.com
Post #465074 Fri Jun 19 2015 6:20am
garrycol
Australia
For sure if you need it, use it.
Dr Rob - surely you have your climate control switched on all year around and let it do its own thing - summer or winter so the A.c will be used all the time - in cold weather the air compressor is still being used to rehumidify the air in the vehicle.
Put it on and let it do what needs to be done. It is forecast to get down to -6c here tonight and I still have my system set to 19 and the car never fogs up. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #465076 Fri Jun 19 2015 6:39am
Screenwipe
Auto access height is standard on the rrs's that are being built now I believe. The paper I saw says it engages when the car is stopped and a door is opened. I don't see that's a lot more convenient than just pushing a button really.
Post #465128 Fri Jun 19 2015 6:10pm
Lost for Words
In the RRS you can use the ECON mode to do that if you don't want full air conditioning. Thumbs Up Visiting from DISCO3.CO.UK
Post #465185 Sat Jun 20 2015 8:44am
DrRob
No ECON button in mine. 2012 car. Visitor from fullfatrr.com
Post #465226 Sat Jun 20 2015 4:19pm
Lost for Words
Ahh, right. Didn't think of that. Thumbs Up Visiting from DISCO3.CO.UK
Post #465228 Sat Jun 20 2015 5:51pm
typhoo12
I have vowed to never touch the height settings, is that bad?
Post #514276 Thu Jan 12 2017 6:03pm
Page 2 of 3 <123>
