Home > My Range Rover Sport > MY RRS BUILD (WITH PICTURES) and Nitrous Oxide
Page 7 of 8 <12345678>
Schoent
Netherlands 2007 Range Rover Sport Supercharged Santorini Black
Bow down car is so nice
Post #435198 Thu Sep 04 2014 9:43am
RRS_Supercharged
Thanks
Not sure its legal but i have medium all round on my other car and never been a problem. ADAIR V8 SC
BRABUS CLK
ABARTH 500 (STAGE 2)
MERCEDES 190e (M104 TURBO BUILD)
Post #435331 Fri Sep 05 2014 1:41pm
RRS_Supercharged
Been a while since my last update as I've been busy working. I've finally got around to working on the nitrous install.
It's an 11lb bottle which will be repainted.
And a max extreme controller to map the nitrous through the entire rev range.
The controller is fabricated into the original dome light housing ADAIR V8 SC
BRABUS CLK
Post #464435 Sat Jun 13 2015 11:24am
RRS_Supercharged
 ADAIR V8 SC
BRABUS CLK
Post #464436 Sat Jun 13 2015 11:29am
s2 wdn
United Kingdom 2005 Range Rover Sport TDV6 S Buckingham Blue
ride hight
Hi nice looking rrs
do you have any pictures of the lowering kit and a picture of the ride hight with the kit on cheers
Post #464513 Sun Jun 14 2015 12:24pm
RRS_Supercharged
Thanks
They are just the links. If you go to low you will lose your access mode. Ill take some pictures in the three stages when i get it back and cleaned! ADAIR V8 SC
BRABUS CLK
Post #464518 Sun Jun 14 2015 1:48pm
s2 wdn
pk cheers
Post #464793 Tue Jun 16 2015 3:11pm
sally
Mmmmmm, I dont know what i think. I like black. Blacks a nice colour.
I guess if we all liked the same think life would be boring. 2012 Evoque
2014 Sport Autobiography
2015 SVR for the fun stuff
2016 Evoque SI4 Dynamic Lux for the daily drive
2016 Defender 90
2018 SVR
Post #464996 Thu Jun 18 2015 8:09am
Simo1976
Bloody lovely Thumbs Up Out and About
Post #465432 Tue Jun 23 2015 5:29am
imb111
2010 Range Rover Sport TDV8 HSE Java Black
WOw Thumbs Up
Post #470559 Mon Aug 17 2015 4:05pm
RRS_Supercharged
Updates
OK so i heard a lot of things about K&N filters causing issues and various things about Pulley upgrades etc.
I have run now with K&N, 10% Pulley, Nitrous and most of my exhaust cut out for 2 years without fault. The car has been custom mapped to take these modifications in to consideration and to squeeze just a little bit more performance out of it.
I am running at about 8MPG and nitrous refills are frequent. I'm running 100bhp of Nitrous progressively mapped throughout the rev range using the MAX Extreme 2 race programmer.
The exhaust modification was to cut out both rear silencers and the 2nd middle silencer. Now when i like it to, it sounds every part the v8 (burbles nicely on downshifts) yet it remains civilised (to a point) when i leave in the early hours and don't want to wake the neighbours!
In these two years i have taken my 70k millage to 132k and it has been faultless... if you don't count the 8 points i have collected for enthusiastic driving. ADAIR V8 SC
BRABUS CLK
Post #523164 Sun Apr 09 2017 3:33pm
TheWojtek
10% pulley? Where from? Do you have a dyno printout before/after pulley & remap? Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #523268 Tue Apr 11 2017 10:23am
RRS_Supercharged
Powerhouse in Sheffield supplied and fitted the 10% pulley
They also did my Nitrous install although the fabrication work was done by an audio shop in Bishop Strotford. I can dig out their name if anyone wants it
https://powerhouse.uk
I didn't Dyno before or after, been planning to get a few more horses out of it before a definitive dyno but life just got in the way. Sad ADAIR V8 SC
BRABUS CLK
Post #523405 Wed Apr 12 2017 11:05am
RRS_Supercharged
from the power house website:
10% 4.0/4.2 V8 Upper Pulleys
The 10% or “2.5lb” pulley does require aluminium removal from the supercharger snout to reduce diameter and allow clearance for this smaller pulley. The task is quite achievable with DIY skills for the keen home tinkerer (I changed my first one on the drive at home), though even some garages are wary to attempt it until they realise it’s actually quite straightforward, if still a bit of a pain! The extra work with a die grinder or mini belt sander pays off, as these pulleys give 35-40bhp/ftlb midrange increase. We have had more than one customer ring us when they return home from having this job done, and say “no way that is only 40bhp!”. The improvement is a black and white difference and gives these cars a new lease of life. 10% pulleys are £158. ADAIR V8 SC
BRABUS CLK
Post #523407 Wed Apr 12 2017 11:08am
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Nice to hear that there is a big difference, as I've been considering this upgrade.
I thought it wasn't really DIY, as the pulley is pressed on, and requires some heating up to fit properly?
Powerhouse uk have an ebay shop, where they'll exchange the whole unit for one that's already fitted with an upgraded pulley. I've been thinking of going down that route, but if it is an easy DIY, I could just get the pulley itself, which is a lot cheaper? 2006 Java Black HST Supercharged
Post #523410 Wed Apr 12 2017 11:35am
