Home > Other Site Sponsors > software updates - Oxford, Aylesbury, northampton Wed 8/4
Bodsy
Site Sponsor
Hi All,
I'll be in the above areas this coming Wednesday 8th April if you are interested in any software updates in or around those areas. Happy to detour off.
I can supply and fit remote FBH kits for all DIESEL RRS/D3/D4 which I have with me Thumbs Up
http://www.rrsport.co.uk/forum/topic39225.html
RRS 2010-2013
Timed Park Heating enable
Remote Control with Timed Park Heating (I have full kits available for immediate install)
Fuel Burning Heater purge/test
Fault Codes read
Gearbox reset/recalibration
reverse follow me home lights
RRS pre 2010 models
Blutooth phone updates
Reverse Follow me home lights
Three Flash Indicator enable
Clock on the dash with or without the Red Lights on Indicator
SatNavOnTheMove update (for Pre 2007 models)
Fault Codes read
Remote FBH controller
Let me know if you are interested.
regards
Ian Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #454480 Tue Mar 03 2015 11:37am
Bodsy
Site Sponsor
. Bodsys Brake Bible
See it HERE
Post #454911 Fri Mar 06 2015 7:51pm
Bodsy
Site Sponsor
Updated date for this weekends movements. Thumbs Up
PM or email me if interested. Bodsys Brake Bible
See it HERE
Post #456572 Fri Mar 20 2015 8:26pm
Bodsy
Site Sponsor
Updated for next date/location. Thumbs Up
PM me if interested. Bodsys Brake Bible
See it HERE
Post #457031 Tue Mar 24 2015 2:42pm
Bodsy
Site Sponsor
now full for the 7th (even doing two at the same time! Laughing )
Edited post for the 8th April Bodsys Brake Bible
See it HERE
Post #457323 Fri Mar 27 2015 11:28am
Bodsy
Site Sponsor
Updated thread for Wednesday 8th April.
Let me know if interested, drop me a PM or email. Thumbs Up Bodsys Brake Bible
See it HERE
Post #458402 Mon Apr 06 2015 4:05pm
Chillbrazil
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Ipanema Sand
Bodsy Hi
Not enough threads on this site (lots on FFRR) but looking at a 2012 RRS and would be interested on costs for the remote park heating and towing electrics.
Need to understand if the Park Heat does warm/heat up the car.
Thank you
Post #463540 Tue Jun 02 2015 10:55am
Bodsy
Site Sponsor
Hiya,
The heat will heat up the water around the engine and in turn the heater matrix. It won't be the same as the RRS2 as that also has a supplemental electric heater. (Not sure if ffrr has same)
But it will increase the engine temperature and put the internal fans on, defrosting the car or refreshing the hot air in summer to make it cooler when the temp is above 15degrees.
Will drop you a PM Thumbs Up Bodsys Brake Bible
See it HERE
Post #463541 Tue Jun 02 2015 11:34am
Chillbrazil
Thank you Thumbs Up
Post #463631 Tue Jun 02 2015 11:16pm
