Home > Australia & New Zealand > Trailer Electrics - Australian Vehicles |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
My 07MY 2.7 did not come with trailer electrics and I bought the OEM loom etc and plugged it into the car systems. Used the black socket and it provides trailer lights etc as per Aust wiring layout. I removed the fuse to one taillight circuit to stop trailer electric brakes operating when the tail lights are on.
Sun May 10 2015 2:22am |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2833 |
only ever used the Black socket on my Trailer electrics.. that said i had to get a
Thu May 14 2015 7:50am |
It has always amazed me that a car maker can sell a car with wiring systems, in this case the trailer wiring system that is not compatible with the specified system in the country of sale - and also that it is not compatible with modern trailer lights systems.
Thu May 14 2015 10:02am |
Opposite Lock who fitted the LED module told me they provided the mod on mostly European
Sun May 17 2015 9:57am |
I also have a Anderson plug setup and it works fine - your point about a low power 12v source in the white plug is valid bit because it is low power it is really not much use for anything then begs the question what use is the white socket.
Sun May 17 2015 12:11pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 260 |
"what use is the white socket?"
Sun May 17 2015 9:36pm |
So other than one pin providing a constant 12v supply what do the other pins do?? 07MY RRS TDV6
Mon May 18 2015 1:05am |
Hi Gary,
Mon May 18 2015 3:03am |
Perhaps its designed for fitting large Flux capacitors on US models Another Pommie Bar Steward down under
Mon May 18 2015 9:38am |
Barry - thanks for that pic. I really cannot see how standard RRS wiring can support the power needs to charge a battery in a camper - especially over the 5 to 6 m from the engine bay to battery in the trailer.
Mon May 18 2015 12:18pm |
Gary,
Mon May 18 2015 12:37pm |
I thinking more I think I will plug in the the wiring to the car but cut off the white plug and run the wiring to two new 12v sockets (pins 4 and 6) in the cargo area as the current single switched 12v socket is a pain when the ignition is turned off.
Tue May 19 2015 9:02am |
Gary,
Wed May 20 2015 10:20pm |
Thanks for that - I see that the fridge wire is switched like to one in the rear - not much use for a fridge on a hot day when parked for a while. 07MY RRS TDV6
Thu May 21 2015 1:59am |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
I have a 06 Sport which had both white and black plugs fitted.
Wed Jun 03 2015 10:57am |
