Home > Technical > How to change FRONT WHEEL BEARINGS
shakeapaw
Ignore step 9, as I couldnt get the senser out, and never even bothered trying on the other side.
Also Step 12 says Push the driveshaft out of the hub. If it does not move then you will need to hammer it out either with a mallet or centre punch.
Do not hit it with a hammer, a simple £10 3 point extractor from Machine mart is all you need 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #461257 Tue May 05 2015 9:44pm
RogerDeFlor
Awesome, mate Thumbs Up I love these posts, I'm one of the (many) amateur driveway mechanics, who are encouraged to do these things for ourselves. Bow down
Should this be a sticky/Knowledge base article ?? Thumbs Up
Post #461865 Wed May 13 2015 8:46pm
shakeapaw
just make sure you know a friendly garage, as I could not undo one of the stake nuts, infact I broke a Clarke four foot long bar on it.
My local garage got it undone with ease, using a 1 inch driver on a 4 foot long Snap On racket, I doubt if any home mechanic has something as big as that knocking about.
And another thing Rolling with laughter , try and undo the Disc Torx screw first before anything else, if it wont losen, then you need to order new ones, about £5 from ebay and then drill them out, one came undone, the other side wouldnt and I ended up stripping the head and my fingers Big Cry Big Cry Big Cry
But you do save yourself a pretty penny and you have the pleasure of knowing that you did it 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #461878 Wed May 13 2015 9:58pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Re: How to change FRONT WHEEL BEARINGS
You forgot one important step between 12 and 13: getting the old wheelbearing out. Not easy, particularly if you do not have a /the right puller. Hammering it out is a pain in the neck and not without risk of damage (see JLR workshop manual)
kav1187 wrote:
Hi Guys,
Here's how I changed my front wheel bearings. Larger pics are available in my gallery.
Tools:
Jack
Wheel Wrench
3 Tonne Axle Stands
32mm Socket
21mm AF Socket or ring end of spanner
15mm Socket
8mm Spanner
13mm Spanner
17mm Spanner
Breaker Bar
Torque Wrench
Hammer/Mallet
Centre Punch
Chisel (flat)
T50 Torx
Thin flat bladed screw driver
Time: approx 1 hour
Torque Settings
Hub retaining bolts - 115nm
Disc support bolt - 35nm
Caliper Carrier (21mm bolts) - 275nm
Caliper bolts - 35nm
ABS sensor bolt - approx 20nm
Hub Nut - 230nm
Wheel bolts - 140nm
Prep:
Lower vehicle to access height
Lock vehicle in access height
Apply Electronic Park Brake (EPB)
Step 1
Using a thin, flat bladed screwdriver, carefully prise the centre cap out.
Step 2
Using the 32mm socket, loosen the hub nut but do not remove
Step 3
Loosen but do not remove the wheel nuts
Step 4
Lower vehicle to access height and lock. Apply EPB then jack the vehicle up remembering to use axle stands to support the weight.
Step 5
Remove the wheel nuts and remove the wheel
Step 6
Loosen the 13mm caliper bolts top and bottom. Use the 17mm spanner to hold the inner nuts still. Do not let the caliper hang by the flexi hose. I found that resting it on the ARB worked for me.
Step 7
Using a 21mm AF socket or ring end of a 21mm spanner, loosen the carrier bolts top and bottom and remove the carrier.
Step 8
Using the T50 torx, loosen the disc support bolt and pull the disc off.
You should be left with this
Step 9
Undo the 8mm ABS sensor bolt and carefully wiggle the sensor out.
Step 10
Use a wire brush and plenty of WD40 to clean the threads of the hub retaining bolts. Undo the four 15mm hub retaining bolts.
Step 11
Use the 32mm socket to remove the hub nut you loosened in step 2
Step 12
Step 13
Fit the new hub/bearing and hand tighten the hub nut to pull the driveshaft through.
Step 14
Fit and tighten the hub retaining bolts to 115nm.
Step 15
Fit ABS sensor and tighten 8mm bolt to approx 20nm.
Step 16
Fit disc and tighten disc retaining bolt to 35nm.
Step 17
Fit caliper carrier and tighten the 21mm bolts to 275nm.
Step 18
Fit caliper and tighten 13mm bolts to 35nm.
Step 19
Fit wheel and hand tighten the wheel nuts. Remove the axle stands and lower the car.
Step 20
Tighten hub nut to 230nm (used to be 275 but LR reduced it to 230 to put less stress on the bearings).
Step 21
Jack up the car. Remove the wheel and make a notch in the hub nut using a flat chisel.
Step 22
Fit wheel and nuts, lower the car and torque tighten wheel nuts to 140nm
Step 23
Fit centre cap
Step 24
Take the locking wheel nut out of the wheel Whistle Rolling with laughter
Step 25
Give yourself a pat on the back Thumbs Up
 RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #548115 Fri Feb 09 2018 6:43pm
shakeapaw
A Bearing puller is £8.95 from Machine Mart. At that price why are you even struggling hitting it with a hammer? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #548122 Fri Feb 09 2018 8:06pm
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Out of curiosity - are we going OEM or Aftermarket? L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #604308 Tue Sep 08 2020 11:22am
Oldandconfused
Most people swear by Timkin bearings, OEM quality without the silly LR cost.
Post #604312 Tue Sep 08 2020 12:33pm
knwatkins
Go for Optimal wheel bearings from Advanced Factors. They are half the price of Timken and come with a 4 year warranty. You cannot get better than that Thumbs Up Kev
Post #604413 Wed Sep 09 2020 11:58pm
knwatkins
https://www.disco4.com/forum/lets-talk-wheel-bearings-184809.html Kev
Post #604414 Thu Sep 10 2020 12:00am
savi18
New Zealand
kav1187 wrote:
Hi Guys,
Tools:
Jack
Wheel Wrench
3 Tonne Axle Stands
32mm Socket
15mm Socket
8mm Spanner
13mm Spanner
17mm Spanner
Breaker Bar
Torque Wrench
Hammer/Mallet
Centre Punch
Chisel (flat)
T50 Torx
Time: approx 1 hour
Torque Settings
Hub Nut - 230nm
Wheel bolts - 140nm
Prep:
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Step 12
Step 13
Step 14
Step 15
Step 16
Step 17
Step 18
Step 19
Step 20
Step 21
Step 22
Step 23
Fit centre cap
Step 24
Step 25
Hi, My caliper carrier bolts were 20mm and not 21mm 2009 L320 on both sides original bolts that came out, Cheers Savi18
Post #639849 Wed Feb 21 2024 10:00am
