Home > Technical > can I safely disconnect my MAF sensor(s)? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8826 |
I think you might get some odd issues. Here's what the manual says about the MAF and what happens when it fails (which is effectively what the car will think if you remove them):
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Apr 19 2015 2:28pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
What is your hypothesis? Do you think there's a problem your MAF meter? Visiting from DISCO3.CO.UK
Sun Apr 19 2015 3:34pm |
Thanks, perhaps disconnecting them wouldn't help much then.
Sun Apr 19 2015 8:27pm |
Could be an EGR issue. The EGRs don't operate until the engine has warmed up which fits. If you ask for throttle and the EGR is tardy in closing you'll have the engine increasing revs with little effect until, bang, the EGR closes and the engine starts pulling. It's a bit like turbo lag and would likely cause some driveline shunt as the torque hits the transmission.
Sun Apr 19 2015 8:46pm |
It's a joy to find someone using the correct word for once... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Apr 19 2015 8:50pm |
I used the 'h' word first and the ironically named LFW gets the plaudit?
Sun Apr 19 2015 9:54pm |
Sorry Paddi!
Sun Apr 19 2015 10:23pm |
It had me confused when I read it. Have you tried a transfer box calibration? No gearbox fault codes presumably? Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Mon Apr 20 2015 9:52am |
Yes - had the transfer box calibrated by an indie some time ago and did it again last week myself using IID Tool (beta version firmware). No change.
Mon Apr 20 2015 12:24pm |
If you install the latest beta firmware for your non BT IIDTool you will find it is possible to display live EGR values. I was doing this yesterday. The live values are not quite what you might expect since the EGR valves seem to spend most of their time open to some degree. Only on throttle does the EGR valve close and then the value changes to 4% even at WOT. At steady throttle on the flat with fully warmed up engine the value settles to the high 50s. Interestingly when cruising on the flat and the transmission jolt occurred if I quickly glanced at the value it had momentarily changed from the high 50s to 4% and then quickly returned to the high 50s again. Would be great to hear from any other users who have tried this on a TDV8 and see if they see similar values. 2008 MY Java Black TDV8 HSE |
Wed Apr 22 2015 12:15pm |
That all makes sense now. The EGR (for some reason) opens, the engine looses power and you feel the effect of engine braking. The TC then unlocks itself as it's still under throttle and isn't expecting this. Visiting from DISCO3.CO.UK
Wed Apr 22 2015 6:11pm |
LFW - Well not quite.
Thu Apr 23 2015 9:52am |
Ahh, yes. Sorry, just re-read your post. So basically it's the reverse effect. Have you been getting smoke/low on power?
Thu Apr 23 2015 10:07am |
No smoke and power is not a problem either. I buried the throttle at about 30 to see what the EGR value did and she was up around 90 in no time. On my private test track obviously 2008 MY Java Black TDV8 HSE
Thu Apr 23 2015 1:38pm |
