Home > General (L494) > Wheel Centre Caps |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 323 |
the idea is, the centre caps are only easy to remove when the wheel is of, as otherwise they are to easy to grab by others...
Thu Apr 16 2015 11:55am |
richamartin Member Since: 16 Dec 2012 Location: Cotswolds Posts: 251 |
I find that a small flat head screwdriver will remove them easily without any detrimental effects.
Thu Apr 16 2015 12:39pm |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 |
Tim,my ours has green centre caps? They should be silver... Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Thu Apr 16 2015 12:54pm |
use a plastic sucker like you get on kids toy arrows or for mounting stuff on windscreen; quick clean easy and no damage !!! |
Thu Apr 16 2015 2:22pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
That is probably what Land Rover's special tool is!! And £100 labour! |
Thu Apr 16 2015 4:19pm |
Chris, just checked and yes mine are silver too, I have the caps from the winter wheels I bought for my Evoque and will be putting them in in place of the plain jane silver ones. Thanks for all the tips - will start with the sucker, graduate to the flat head screw driver and then as a last restort take the wheels off, but that sound like a lot of work on a hot evening........... when I should be having a cooling beer. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Apr 16 2015 4:29pm |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
Don't use a screwdriver, you will mark the wheel. Use a plastic pry-tool instead. Far better though to remove the wheel. Mark
Thu Apr 16 2015 8:48pm |
kbklr Member Since: 27 Jan 2013 Location: Aberdeen Posts: 26 |
+1 for the sucker method - valve grinding tool with a smear of grease |
Fri Apr 17 2015 8:59pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
My centres were U/S,as the paint had flaked off because power hose use. So as not to damage wheels. I drilled a small hole in the centre cap and screwed in a srew then just pulled them off itisme |
Sat Apr 18 2015 2:22pm |
