Home > General > Noisy seat tdv8 hse |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Need to take it to a dealer, the rocking seat issue is well known and LR modified the seat base and mechanism. My car had creaking seat, was changed and became a rocking chair and was finally fitted with the update at about two years old. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Jan 24 2015 9:05pm |
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 134 |
Hi , do you think I might be able to get it sorted under a non landrover warranty at a main dealer ? Just wondering if this problem is classed as wear and tear or manufacturer fault ? Only way to find out I guess is to phone my nearest dealer tho I doubt any good will come of it 😩 |
Sat Jan 24 2015 10:45pm |
As its a known issue, they can hardly dismiss it. Might be good to speak to customer relations once LR dealer has diagnosed issue 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Jan 24 2015 11:45pm |
Ok thanks simple1 worth a try |
Sun Jan 25 2015 8:31am |
