Home > Maintenance & Modifications > Cheap fix for GPS Aerial. |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Once you take it apart it's pretty obvious really.
Sun Jan 04 2015 7:21pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Have you not read this document
Sun Jan 04 2015 10:13pm |
Techstyles Member Since: 22 Dec 2014 Location: Antwerp Posts: 46 |
Hi Flack,
Sun Jan 04 2015 10:22pm |
Yes reattach the Fakra connector and then ignore the old aerial lead and thread the new lead down the passenger's side of the car to the Sat nav DVD drive under the passengers seat and connect it to the unit.
Mon Jan 05 2015 10:11am |
Hi flack
Mon Jan 05 2015 10:33am |
That is how I understood it Panda, I would much rather do it your way and solder the old cable onto the new gps aerial board. How did you open the new gps casing?
Mon Jan 05 2015 11:34am |
The only problem doing it this way is if the cable has got water damage further down inside the cable then it will not last, thats why I went for the new cable run just to be sure, The trouble is with this type of cable once water starts to get inside it acts like a capillary action and just draws more inside.
Tue Jan 06 2015 2:28pm |
So the PANDA was lucky doing the work in the roof lining.
Tue Jan 06 2015 5:39pm |
Yeah reckon so but its still raining so gonna wait for some dry weather.
Tue Jan 06 2015 6:43pm |
I would think flack would know but it looks good to me.
Wed Jan 07 2015 9:14am |
Yes looks ok to me.. Why a 15mm hole ? if your referring to the blue Fakra connector then take it off as in the Pdf file and then its about 6 or 7mm hole that you need.
Wed Jan 07 2015 9:22am |
Great thanks Flack. About to order the piece in that case.
Fri Jan 09 2015 9:03am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Hi Flack,
Wed Oct 12 2016 2:18pm |
Radioham 49 Member Since: 05 Jan 2015 Location: Maidstone,Kent. Posts: 9 |
Followed the instructions sat nav now working OK again.many thanks for the info Flack. Regards. |
Sun Mar 12 2017 1:41pm |
