Home > Maintenance & Modifications > Cheap fix for GPS Aerial.
Page 2 of 3 <123>
panda
Once you take it apart it's pretty obvious really.
Post #447410 Sun Jan 04 2015 8:21pm
Techstyles
Belgium 2005 Range Rover Sport TDV6 HSE Maya Gold
Well I will firstly admit Im a noob when it comes to DIY so pls do humor me. Smile
So Im right in that it's just the circuit board that needs replacing?
Can you also explain how to open up the side covers, do they just pop off? Bit hesitant In case I break something. Hence wanna know as much as possible before I attempt it. The tip you gave on the dry weather is also great as it's been raining a lot here lately so that would have been a pain as you mentioned.
Don't suppose you have a link to the aerial you bought?
Post #447418 Sun Jan 04 2015 10:08pm
flack
Have you not read this document
http://www.rrsport.co.uk/gallery/albums/us...%20RRS.pdf
Flack Thumbs Up
Post #447427 Sun Jan 04 2015 11:13pm
Techstyles
Hi Flack,
Yes I did read it but had a couple of questions, like in your doc you remove the fakra connector, pass the cable through the base plate after drilling a hole and connect the gps aerial inside the shark fin. But what then? What do u do with the new aerial with the cable with no fakra connector on it? Do u reattach? Connect it to the old cable or pull it down somewhere? it didn't mention this in the doc and Im new to this so appreciate the guidance.
Thanks
Post #447428 Sun Jan 04 2015 11:22pm
flack
Yes reattach the Fakra connector and then ignore the old aerial lead and thread the new lead down the passenger's side of the car to the Sat nav DVD drive under the passengers seat and connect it to the unit.
Or buy one of these and connect it up and stow the cable under the panel, but you will have a lot of cable to hide.
http://www.ebay.co.uk/itm/Connects2-CT27AA...3f1d0d55b0
There might be shorter ones ?.
Flack Thumbs Up
Post #447447 Mon Jan 05 2015 11:11am
panda
Hi flack
Done all my work above head lining. Didn't need to run new cables.
PANDA
Post #447448 Mon Jan 05 2015 11:33am
Techstyles
That is how I understood it Panda, I would much rather do it your way and solder the old cable onto the new gps aerial board. How did you open the new gps casing?
Did you destroy it by doing so and was it easy to solder the old wire onto the board as in could a total noob do it easy enough?
If you have a moment could you look at my photo on the previous page and confirm if the gps fakra connection is the one on the far left of the nav unit?
Post #447455 Mon Jan 05 2015 12:34pm
flack
The only problem doing it this way is if the cable has got water damage further down inside the cable then it will not last, thats why I went for the new cable run just to be sure, The trouble is with this type of cable once water starts to get inside it acts like a capillary action and just draws more inside.
Flack Thumbs Up
Post #447557 Tue Jan 06 2015 3:28pm
panda
So the PANDA was lucky doing the work in the roof lining.
Techstyles why don't you get part, leave cable long so work done above head lining. If you get problem later date run cable through.
Post #447569 Tue Jan 06 2015 6:39pm
Techstyles
Yeah reckon so but its still raining so gonna wait for some dry weather.
I'm found this is aerial, what do you guys think? Will it be ok? Only thing is its 15mm I have to drill then.
http://www.banggood.com/GPS-Antenna-for-Fa...wgodioIA9A
But once it arrives I know I will probably start the mod.
LED's arrived in the post today so got something to keep me busy with in the meantime.
Post #447579 Tue Jan 06 2015 7:43pm
panda
I would think flack would know but it looks good to me.
Post #447649 Wed Jan 07 2015 10:14am
flack
Yes looks ok to me.. Why a 15mm hole ? if your referring to the blue Fakra connector then take it off as in the Pdf file and then its about 6 or 7mm hole that you need.
Flack Thumbs Up
Post #447651 Wed Jan 07 2015 10:22am
Techstyles
Great thanks Flack. About to order the piece in that case.
Will post up an update when I get a chance.
Post #447902 Fri Jan 09 2015 10:03am
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Hi Flack,
Great but could you tell me what length cable I need?
I presume 3m should be enough.
Thanks in advance
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #507655 Wed Oct 12 2016 3:18pm
Radioham 49
United Kingdom 2005 Range Rover Sport TDV6 HSE Stornoway Grey
Followed the instructions sat nav now working OK again.many thanks for the info Flack. Regards.
Post #520676 Sun Mar 12 2017 2:41pm
Page 2 of 3 <123>
