Home > Technical > Raspy noise when lifting foot of Accelerator |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
It's normal. Mine has done it for the last 20k+ Miles |
Mon Jul 21 2014 5:50am |
W33 RRS Member Since: 21 Aug 2010 Location: Carlisle Posts: 68 |
I took my RRS to the garage today and it turns out one of the EGR valves are stuck half open and the noise is probably from that, hoping to get it fixed of my warranty so will find out if it's cured soon and by fixed I mean deleted |
Tue Jul 29 2014 6:34pm |
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 |
if the ERG valve is stuck half open does that affect the performance |
Tue Jul 29 2014 7:10pm |
I couldn't tell you, this is the first and only one I have driven and only had it 3 weeks, and it came like that. So I don't know any different.
Tue Jul 29 2014 7:36pm |
ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27 |
Did you find a fix for this?
Sat Jan 24 2015 9:52pm |
Hamner Member Since: 28 Jan 2015 Location: Swansea Posts: 54 |
hi ace i have that rasping sound on my 2.7 hse 2005 its been there since i bought it 18 months ago i took it to stratstone who couldent pin point it and said just keep an eye on it but some one said it might be the actuator arm near the turbo sticking or just dry and to try and get a squirt of oil on it which is not as easy as it sounds havent got that far yet so cant say it works but someone might have cheers Hamner |
Thu Jan 29 2015 4:15pm |
It's not the turbo actuator arm |
Thu Jan 29 2015 4:32pm |
hi mikey thanks for that up date another job of the list any idea what it is i also had my egr vaives removed to try and stop the rasping but didnt work cheers Hamner |
Thu Jan 29 2015 4:40pm |
I believe it is turbo or gearbox related... |
Thu Jan 29 2015 6:56pm |
cheers mikey that clears up a lot of theories getting closer to solving the mystery rasping thanks hamner |
Thu Jan 29 2015 7:07pm |
It's not the gearbox
Thu Jan 29 2015 7:41pm |
hi ace . i have had my rrs 2.7 hse to the main dealer with this rasp noise they check the turbo which was showing no problems they said it might be the actuator arm which Mikey has ruled out you have ruled out gearbox because you changed that . so were down to torque converter as you say ive never changed mine so im wondering if you or mikey have ever changed yours all the records on my car dont mention this item being changed so im wondering if a new torque converter would solve the rasping sound or someone on forum may of change the converter and still got the noise hope this helps maybe between us all we my get to the bottom of it cheers Hamner |
Fri Jan 30 2015 5:46pm |
sorry mate i see you have changed your torque converter a few times so that doesnt work either |
Fri Jan 30 2015 5:54pm |
Hammer I know what the problem is but I'm not sure as yet how to fix it.
Fri Jan 30 2015 7:27pm |
