Home > Maintenance & Modifications > Chip box and fuel consumption |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Presumably you are getting your MPG figures from the computer which has been confused by your chip box. Things are not what they appear to be. The chip box is usually just an additional resistor plugged into the cars electronic circuit which tells the injectors to over fuel the engine so by turning it to maximum the chip box has just increased the over fuelling to the next level
Tue Jul 29 2014 10:28pm |
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 |
I decided to do test monitoring mileage, I filled up with fuel, so far I have done 247 miles and I have left in the tank between half and 3/4 , dash is telling me I have 307 miles left but we will see how that really turns out over next few days. However it does seem better so far by quite a bit, and power is awesome, it is also so much smoother . Fingers crossed things stay the same. Rich |
Sun Aug 03 2014 9:22am |
Quick update, I got to 503 miles then filled up again , comp said I still had 26 miles left , so all in all better for me by far. |
Fri Aug 08 2014 10:07pm |
Have you been driving it normally though or driving for economy?
Sun Aug 10 2014 10:15am |
