Home > General (L494) > Max fan speed
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Max fan speed
Normally I have the front + rear aircon/climate on auto, but as it was a very wet day + 2 dripping dogs in the back, decided to put the fans on max...but there's not much extra waft from auto, just a slight flow of air but not much else. You can hit max aircon, which drops the temp to min, but for max heating and max fan speed it seems to be quite feeble. All vents open, but turning both fans to max, the output seems pretty weak!
Post #408280 Mon Jan 06 2014 12:19am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
please donīt let that be true.....
It can drop to -20 here some nights.... ima gonna need all the fan speed I can get...... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #408286 Mon Jan 06 2014 1:07am
Disco
On our old Disco the max demist / windscreen button was very good for the condition you mention. Yes it auto selected which vents it used but that is for reason. Give it a try mate.
Post #408372 Mon Jan 06 2014 7:53pm
Disco
If you leave the temp set to Auto then it will still do what it thinks you need, if you want max heat try to wind the temp up manually as well.
Post #408373 Mon Jan 06 2014 7:54pm
peanutbob
Hi Disco
Thanks for the reply. Though that is what I've been doing, cranking the blowers up to max speed...but only a gentle breeze is forthcoming, probably just enough to blow a match out.
(I had a 59 plate Defender lwb and putting the fan onto max plus front vents meant you could blow dry your hair very swiftly!!)
Post #408382 Mon Jan 06 2014 8:51pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Select the vents too?
Post #408384 Mon Jan 06 2014 9:01pm
peanutbob
All vents open front and rear! Going from auto to max fan speed increases the output very slightly. No great whoosh of air!
Post #408386 Mon Jan 06 2014 9:08pm
Disco
What if the auto function was calling for max anyway? It would not turn up any more.
Or is it really that bad, 8.5 stone of wet Newfoundland will give a testing when our pup gets wet.
Post #408387 Mon Jan 06 2014 9:12pm
peanutbob
Ahead of you on that one! I thought of that over the weekend. On auto there is a steady trickle of air, which has been the same since October, hit max fan and there's slightly more air but not a lot
I've a digital sound meter which should record the difference in decibel volumes from auto to max. Might give that a go tomorrow!! Laughing
Post #408388 Mon Jan 06 2014 9:20pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Have you turned auto climate off before turning fan to max? 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #408601 Tue Jan 07 2014 10:31pm
