| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Altimeter |
| M@verik Joined: 16 Aug 2005 Location: Somerset Posts: 129
Has anyone found out if there is a means of calibrating the altimeter function in the Off Road Navigation?
| RRUK Joined: 10 Jun 2005 Location: Certainly In-Vogue Posts: 2288
I think it's correct. As far as GPS readings arew concerned, you are typically 200M+ above SEA LEVEL in the UK.
RRUK - thanks but with respect if you believe that, you've been listening to too many of the less well informed Landrover dealers who have been slated elsewhere, the ones that fob you off with any old guff that is.
| Biggles Joined: 26 May 2005 Location: Preston, Posts: 916
I have noticed this, we were sat on the beach at Blackpool and the altitude was showing 250 feet. Somebody needs to tell my car that its wheels were in the sea. Should have been a below sea level reading |
| MDP Joined: 14 Jun 2005 Location: Back in an AUDI Posts: 8598
what I can't understand is what is the point of equiping the sat nav system with an altimetre that doesnt work? If you are unable to adjust it or it doesnt show correct readings..... its pointless and need'nt be there at all. |
You might be better off packing your trusty sextant ....Cpt J Cook never had any bother with his.... |
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 2012
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 8082
My SE doesn't have the nav system but what interests me is what it tells you if you go offroad and into the wilds, can anybody tell me? I have 2 systems available on my Ipaq PDA with GPS - Navman for point to point with voice directions for on-road use and then I have the Memory Map Navigator Digital Ordnance Survey maps for the entire UK also loaded on an external memory card (3 Gbytes of memory are required for the maps so I have a 4Gb micro drive). The MemMap system can be stablised with the car in the centre of the screen and the map scrolls along as the car moves and also a "track" line is drawn on the OS map, what it cannot do is give you voice directions to your destination, but at least you can read the maps either as a UK road map or an OS map with all the usual detail and see exactly where you are.
| All times are GMT |
Staying - Epsom Green Defender 90 for playing off road
