Home > Faults & Fixes > Poor battery connections |
I find that loosening them off, then a gentle tap back down with a hammer (gentle!) then hold the clamp down whilst tightening the bolt back up does the trick.
Mon Jan 28 2013 9:36pm |
overfinchred Member Since: 20 Dec 2012 Location: Northants Posts: 65 |
it is a genuine Jaguar/LR battery but no mater how tight I spanner the connection it will just pull off - it seems as though the connector is no good and do not want the hassle of changing this
Tue Jan 29 2013 3:30pm |
If you bought it from a dealer, they should fix it. Otherwise the pos cable Inc megafuse is about £250. You can't get the clamp or the bolt on it's own, but a breakers may be able to supply.
Tue Jan 29 2013 3:35pm |
Failing that, if you can get som every thin lead, you could place a little inside the clamp so you can tighten it. Bodsys Brake Bible
Tue Jan 29 2013 3:37pm |
