Home > Wheels & Tyres > Strange feathering on front tyres |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Silly question I know but have you checked tyre pressures - I guess under inflating could lead to both outer edges wearing ?????? FF 4.4 V8 Soooo looking forward to this bad boy
Thu Jul 12 2012 9:33am |
Sounds like it needs a 4 wheel alignment again.
Thu Jul 12 2012 10:53am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
Pressures are ok but will monitor them more often to be sure
Thu Jul 12 2012 11:00am |
could be putting more load on the tyre shoulders yes..
Thu Jul 12 2012 11:05am |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 286 |
Swap front to rear will help with wear but it does sound like you need 4 wheel alignment. Please call us 01737 241370 for the quickest response
Thu Jul 12 2012 11:42am |
It's going in for the ARB work on Thursday next week so hopefully I can keep the mileage down until then. Once that is done I can get the alignment checked.
Thu Jul 12 2012 2:00pm |
Spoke to a LR indie (James French near Oxford) who do 4-wheel alignment. They advised that I may as well wait until the ARB is done because, usually, bits of suspension need to be removed to change it. Thus it will need to be aligned after the work anyway.
Fri Jul 13 2012 3:24pm |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 |
Hmmmm,think mine are doing the same,my fronts are starting to wear on the inside only on both fronts, whats the correct pressure for 275/40 R20 106Y continentals, and pressure for the Rears please 2007 COOLRRS |
Sat Aug 11 2012 12:29am |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
36 all round for me. |
Sat Aug 11 2012 8:34pm |
