Home > Technical > Suspension problem |
chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123 |
Ill add my name to the list of people with suspension faults.
Tue Jan 10 2012 10:30am |
Car now booked in for next Wednesday to have a new compressor and relay fitted. So it takes 2 weeks to get a compressor from JLR and then the dealership cant book the car in to even be seen for another week.
Thu Jan 26 2012 11:17am |
Katrina999 Member Since: 23 Sep 2011 Location: Ayrshire Posts: 13 |
Hi Justin
Tue Feb 14 2012 8:24pm |
justin ashbourn Member Since: 14 Feb 2012 Location: oxford Posts: 2 |
Katrina thanks for the reply, I hope your problems stop soon as these are such great cars to drive, good luck. x |
Wed Feb 15 2012 9:44am |
Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147 |
Hi guys, think I'm beginning to have suspension problems. The dash all lights up, goes into safe mode and says suspension lowered etc. turn off and back on and all fine. Can go weeks with no problem or can go again 2 minutes later. There's times as well I've thought the passenger side rear has dropped all of a sudden then rights it self!!!! Is there anywhere near Liverpool you could recommend me taking it without getting ripped off as well. Thanks. Mike |
Sun May 13 2012 12:12pm |
cobbler2u Member Since: 09 May 2010 Location: hertfordshire Posts: 69 |
Have same problem.
Tue Apr 02 2013 12:32am |
Coxylad Member Since: 11 Jul 2013 Location: Preston Posts: 48 |
I'm not liking the sound of all this. I have just bought my RRS 2.7tdv6 2007 last month it has 37.000 miles on the clock Is this when all the problems start, I really hope not. I have only done 90 miles in it sice IV had it as I'm away working in Egypt so I'm hoping for trouble free motoring when I get home Should you raise and lower the suspension on a regular basis to keep all the parts active or should you just leave them alone as I only plan on doing normal road use. Thanks 2007 RANGE ROVER SPORT 2.7 TDV6 HSE in silver |
Tue Jul 23 2013 12:41am |
Tue Jul 23 2013 12:45am |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
i was told to lower it overnight as it saves battery. thats made things worse and now i need a new compressor too. apparently regularly raising/lowering turns the compressor into an old man basically. 07 TDV8 + BAS map |
Mon Aug 12 2013 12:22am |
Andyred90 Member Since: 12 Sep 2013 Location: United Kingdom Posts: 9 |
Had this problem with a D3 and it turned out to be camber angle sensor. Reset and never any further problem. |
Thu Sep 12 2013 10:24pm |
overfinchred Member Since: 20 Dec 2012 Location: Northants Posts: 65 |
I have a 2008 model that has done this twice and then I turn off and back on again and fault clears? “One good thing about music, when it hits you, you feel no pain.”
Sun Sep 15 2013 8:15pm |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 |
For what it's worth, mine came up with the Amber Suspension Warning Light, which was intermittent on when it came on, i.e - 5 minutes into drive, 15 minutes, 40 minutes!! Suspension was slow to raise, sometimes didn't at all, sometimes raised and never went down - it basically did what it wanted to do!!
Wed Jul 09 2014 5:33pm |
l Member Since: 11 Jun 2005 Location: Valencia Posts: 232 |
Incredible but true I have found a mechanic two miles away from my house who knows how to repair compressors!!! He took mine apart cleaned it out changed seals and it is working correctly. RRS TDV6 HSE BUCKINGHAM BLUE BLACK LEATHER INTERIOR RHODIUM TASMOD SILLS PARROT 3000 EVOLUTION WHITE SIDE REPEATERS RRPORT.CO.UK BROLLY & STICKER
Wed Jul 23 2014 1:16pm |
