Home > Maintenance & Modifications > Rubbery plastic under the wheel arches
m3grant
This is the first time I've posted on here, really hope someone can help me with this little annoyance on an otherwise amazing car!
Around the edge of the wheel arches there is a kind of rubbery plastic which I assume is to keep mud and water out of the body of the car. It's a kind of wheel arch inner lining I guess. The problem I have is that it used to sit snugly against the underside of the wheel arch panel but has not started to come away from the bodywork in places. It looks like the sort of material that might respond to a blast with the hairdryer to help me mould it back into position. Any thoughts or experience of this before I head outside with my wife's hairdryer? Smile
Grant
Post #323979 Mon Dec 05 2011 11:21am
i believe its there to protect the arch edge from stone chips, but whilst doing that they become crud catchers
try taking off, cleaning the arch and strip and then replace, if not, I recall they are not vast amounts of money to replace with new
Post #323980 Mon Dec 05 2011 11:24am
Linko
Sounds like the wheel arch protectors to me too. They tend to get water build up inside of the rubber which causes them to come away from the arch. You can faff with them to to make them fit/look better, but I replaced the lot and they look a lot better.
The part number for the front protectors is CLB500051. They are about £5 each ISTR.
They are easy to slide off and replace unless you have mud flaps fitted (front). The screws on mine were a nightmare to get off.
Cheers,
Mark
Post #323995 Mon Dec 05 2011 12:59pm
Chicken George
United Kingdom 2009 Range Rover Sport TDV6 S Santorini Black
hair drier wont help its the steel spring inside the rubber strip that has rotted.
Post #324002 Mon Dec 05 2011 1:15pm
m3grant
Thanks everyone. Just ordered them from my local dealer. £7 for a pair (front and back)!! Cracking stuff. Thanks again!
Post #324012 Mon Dec 05 2011 2:29pm
panda
m3grant
Do you have front and back part numbers as I would like to order both sets.
Thanks
Panda
Post #324018 Mon Dec 05 2011 3:44pm
gilford
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Had mine done under warranty, 5 minute job Wink
Post #324023 Mon Dec 05 2011 4:21pm
duckworthparts
Site Sponsor
Front CLB500061 £12.50+vat each
Rear CLB500051 £13.50+vat each Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #324024 Mon Dec 05 2011 4:40pm
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
has anyone got a pic of these...the price seems really low for a big lump of plastic
Post #324026 Mon Dec 05 2011 4:54pm
ronniet101
Post #324027 Mon Dec 05 2011 4:54pm
panda
Hi ronniet101
If you copy paste part number put into google Brit car parts have picture of it.
It is actually a 300mm - 400mm u shaped rubber strip with steel inner pushed onto wheel arch. Its not the complete plastis inner wing. Just looked at mine easier to fix than I thought.
Panda Thumbs Up
Post #324031 Mon Dec 05 2011 5:11pm
panda
Ordered mine today ( Duckworth Parts).
Will let you know how easy to fit. Thumbs Up
Post #324253 Wed Dec 07 2011 12:12pm
ronniet101
does anything have to be removed to fit these..or are they just a push on fit
Post #324589 Fri Dec 09 2011 3:32pm
just push on iirc RRS gone
Post #324594 Fri Dec 09 2011 4:11pm
ronniet101
thanks
Post #324595 Fri Dec 09 2011 4:14pm
