Home > Tips & Tricks > Tricks to correct uneven wear Contis?
flydive
Because is a pain to explain to the cops that is feature of the RRS/Conti combo and they might not listen Wink '08 RRS TDV8
Post #283158 Thu Dec 16 2010 9:26am
Tboner
what is the law on tread depth across the % of a tyre width 2014 5.0SC AB
Gone 5.0 SC
Post #283161 Thu Dec 16 2010 9:49am
flydive
I do not know the law in UK, do not drive there, I know they will give me hard time here, and even if I was ok I'd still have to waste time discussing the issue with them. Knowing as some of them work they then might start looking for other problem just to "win" Wink '08 RRS TDV8
Post #283162 Thu Dec 16 2010 9:56am
smurf
what tyre pressure is everyone using in the conti's,on the drivers door i think it says 42 rear and 36 front this is with 4 passengers and luggage.i very rarely have 4 passengers + luggage.and what pressures do i use when towing a caravan.any advice please.sorry for hijacking the thread
Post #283172 Thu Dec 16 2010 11:31am
redrover
Australia 2007 Range Rover Sport TDV6 HSE Java Black
Regardless of tyre, i always go for the max load pressure recommendation. Slightly hard ride, much better handling and wear. TDV6, MYO7 Java with Ivory leather, 19 inch wheels
Post #283328 Sat Dec 18 2010 11:45am
muddywheels
Milk Float Man
A minimum of 1.6mm in a continuous band throughout the central three-quarters of the tread width, throughout the whole of the circumference (see illustration below).
I tow a caravan and inflate for 4 passengers and luggage when towing then decrease to lower pressure on door when I unhitch after tyres cool down - min 3 hours. I keep a small compressor in boot with a tyre gauge Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #283334 Sat Dec 18 2010 12:27pm
Kato RRS
Scotland 2008 Range Rover Sport TDV6 HSE Siberian Silver
Rudskibaliblu wrote:
This is a section of a technical bulletin that i recieved after compaining the outer edges were wearing uneven. Quote A customer may report uneven tyre wear on vehicles fitted with 20" wheels and Continental sport contact tyres.
Cause: Due to the tread pattern design of this tyre, there can appear to be inner or outer shoulder wear. This is in fact just the natural tread wear, but as the design of the lateral grooves continues around the sidewall, the very ends of the grooves do not wear giving rise to a "band" of wear at the edge of the contact patch.
Action: No action is required for this issue as it is deemed a characteristic of the tyre and not a fault.
Make of this what you will they still look bloody worn to me!! Big Cry
Unless this part of the tyre is designed to wear quicker than the rest then the tyre is illegal when the base of the groove of any of the original tread pattern is not clearly visible. Reg 27 construction and use regs. Unless this has hanged of course. RRS for on road
1985 LR 90 for off road
Dolomite Sprint for fun
Post #422775 Tue Apr 29 2014 8:42pm
