Home > Australia & New Zealand > Technical |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Assuming they are not empty fuse.... i think it is the same fuse that controls the cigar lighter - is that working ?
Thu Oct 21 2010 10:21am |
.... but thinking about it now IIRC it is the headlamp jets that share the cigar lighter fuse...
Thu Oct 21 2010 10:23am |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
I believe the pollen filter is inside the car behind the glove box. If you check in Bobby's gallery I think you will find the information you require.
Thu Oct 21 2010 1:38pm |
Garrie2283 Member Since: 01 Jul 2009 Location: coal point New South Wales Posts: 14 |
Thanks Guys I will check out both resposes and let you know the results. My headlight washers seem to still work correctly
Sun Oct 24 2010 11:19am |
The headlight washers are serviced by a separate pump.
Mon Oct 25 2010 5:27am |
Hi all, Many thanks for all the help to resolve my queries, the Pollen filter is now fitted and the washer failure seems to be the pump as the fuse is ok and the rear wash is also out. I will pull the pump out for testing as soon as time permits.
Wed Oct 27 2010 9:33am |
