Home > Technical > MY10 iPod Charger does not charge |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Sun Sep 13 2009 4:02am |
Umberto, I've split this into it's own topic and stickied it as I'm sure it won't be the last we hear of it.
Mon Sep 14 2009 6:45am |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
Thanks for posting, now I know why my ipod / iphone are not charging. and you cant go back on the apple software/firmware grrrrr.
Mon Sep 14 2009 6:48am |
I should also mention that at least one owner of a new 2010 FFRR here in the US tried the above charging adapter and reported it didn't work, his iPhone 3G still won't charge although it will interface fine with the touchscreen. |
Mon Sep 14 2009 5:51pm |
Update: Apparently the Scosche PassPORT Car Charging Adapter is available with two manufacturing dates, they should be printed on the package. Same model # and nearly identical look, so it's hard to tell the two apart otherwise. Make sure the adapter you will purchase is dated 2009, according to a forum member on rr.net the same device dated 2008 will not charge his iPhone. |
Sat Sep 19 2009 6:23pm |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
The problem is caused by Apple changing the charging specs of the iPods, and the manufacturers/OEM suppliers then have to play catch up - within their normal long lead times, etc etc.
Sat Oct 03 2009 5:42pm |
My iPod/iPhone will charge through the USB in the upper glove box, it will even play through it, but it dosn't charge through the iPod dock. I have to use the USB cable that came with the iPhone tho. Sons of dogs come hither and get flesh
Sat Oct 03 2009 6:40pm |
aarenlainey Member Since: 01 Apr 2010 Location: UK Posts: 1 |
There are many problems about i pod charger If you get a new i Pod for Christmas, keep a careful eye on it during its first charge/update. You’re supposed to leave it charging for hours to ensure everything nicely calibrated, but while getting a video i Pod set up ready to give to someone I eventually noticed it had stopped charging after all the tracks had been transferred,so there are many problems in new products. Defeat is not bitter unless you swallow it. |
Mon Apr 05 2010 5:09am |
Tboner Member Since: 03 Dec 2008 Location: Bucks - UK Posts: 447 |
My 3GS with os 3 or os 4 is fine on a 2010 car delivered last week 2014 5.0SC AB
Wed Jul 07 2010 5:41am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
This is an old tech bulletin though.
Thu Jul 08 2010 11:57am |
Megan Member Since: 12 Sep 2010 Location: Michigan Posts: 2 |
OK, if this issue is really fixed, could someone please tell me what parts I need change on my early 2010 RRSSC to allow my i-phone/pod to charge while in use? I did buy the Scosche PassPORT adopter, and it worked well at first, but because it's fitment makes the i-phone longer than the storage area in the center console easily accomadates, it didn't take long before the connection on the Scosche became loose and unreliable. Megan |
Sun Sep 12 2010 9:59pm |
OK, figured it out myself without help from experts in the motherland,.........
Tue Sep 14 2010 3:36am |
rr5port Member Since: 08 Jun 2011 Location: Northampton Posts: 43 |
Just took delivery of a 10MY, and my iphone3gs charges ok |
Fri Sep 23 2011 4:16pm |
SALMON FISHER Member Since: 13 Jan 2007 Location: ,GLASGOW Posts: 115 |
Just bought a 59 RRS and sent for the iPod connecter ,its coming up device error after saying connecting to iPod .
Thu Dec 06 2012 4:27pm |
