| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Maintenance & Modifications > Best roof rack for kayak |
| Smarticus Joined: 26 May 2005 Location: Northumberland Posts: 588
I believe the RRS uses the same roof rail system as the Disco 3. In that case the LR supplied roof bars are only rated to cover about 100 lbs of weight, which is very low. In LR pictures you will only ever see 1 kayak attached to the roof. In real life we need a roof rack system that carries at least 4 kayaks (on their sides). As we use Prijon boats (hard dense plastic), the weight would be well over 100lbs so when used like that it would be out of recommended parameters with possible consequences for insurance, road saftey etc. I suspect the roof rack would be well capable of carrying that weight but LR are deliberately leaving a huge margin for error. Having said that I suspect the weak link is the roof rails themselves, and if a vehicles was in a fast speed collision when carrying a heavily loaded roof rack, I wouldn't be surprised if the rack was to part company with the roof thereby launching a very heavy missile to do even more damage to what ever the vehicle hit. Other things to worry about is the difficulty in loading a rack which is so high up, and the effect on the vehicles centre of gravity. |
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 7170
Smart 100lbs is only 50kg so you can load a few more up there before you reach the 75kg weight limit! I too use a roof rack a lot but hate with a passion these roof rail systems, I think they ruin the lines of the wagon, same with the big RR on which I used the sports bars when I wanted to carry more windsurfers that would fit on my small Ivor Williams P60, 6ft x 4ft trailer. The other draw back is that the roof rail systems are permenent and create a heap of extra wind noise and drag. Sports bars cannot be fitted to the RR Sport as there are no little flaps in the roof like the big RR had for them to screw into.
| Renny Joined: 01 Jun 2005 Location: Fife Posts: 21
Didn't know you were into wind surfing Tim. K has just started and got her RYA 1 whilst out in Turkey a couple of weeks ago and wants to progress, but nowhere near us to hire kit.
Renny the garage loft is bulging with 3 boards, 6 masts, 10 sails, 5 booms..... well you get the picture! That's why I have a trailer.
