| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > General > Does anyone else get a driveline shunt at low speeds?SORTED! |
| gazza500 Joined: 01 Aug 2007 Location: Channel islands Posts: 128
I have an '07 TDV6 HSE. No drive line shunt, just the annoying rattle from the dynamic response system. Chawton White TDV6 HSE with Alpaca and Rodium, Automatic Climate Control,
| Diablo Joined: 28 Jan 2008 Location: UK Posts: 29 |
Gents,
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20732
Good to hear Diablo... |
| cowey101 Joined: 17 Jul 2007 Location: Gods country! Posts: 392
55 reg HSE, 31000 miles, low speed shunt problems too |
| ROB.T Joined: 21 Nov 2006 Location: LEICESTER Posts: 4
Had same shunt problem for over two years 06 HSE 33000 miles ,Do you think dealers would exchange information on fix. |
| dai748 Joined: 08 Feb 2008 Location: Wales Posts: 8
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 1214
In LR speak = characteristic or inherent part of the car
| enzojunior Joined: 25 Jun 2008 Location: Sydney Posts: 18
My dealer said, "normal". He suggested that when these cars cruise along off-throttle, they put themselves into neutral to save petrol. So what is happening, if that is the case, is the gearbox re-engaging. Wierd?? 2006 Black/Alpaca, Hi Ice, Dynamic Pack, 19" wheels, Clear Pack... |
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 8082
Enzo I think your were told the first thing that came into the service managers head............................... when the car is cruising on a light throttle then the fuel ECU reduces and can even stop the fuelling to save fuel, the gearbox doesn't go into neutral A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
| dustin Joined: 02 Sep 2008 Location: Norcross, GA, USA Posts: 2
This clearly feels like a transmission firmware calibration issue. The transmission mechanically is probably okay. Its likely that the shift points (shift schedule) and torque converter lockup schedule were not properly calibrated from the factory. I feel the same thing on my 2006 Range Rover Sport. It feels like the transmission is "hunting" for a gear.
| XXXAngelXXX Joined: 03 Mar 2006 Location: assimilated....... by the Britts - since 1995 ! Posts: 5470
its a know prob with the 6 speed ZF auto gearbox - i had it on my former 2 Jaguars and on a friends BMW 7 but never had it with the RRS |
| 2nd Rower Joined: 12 Nov 2007 Location: VIC Posts: 382
I had one of those "software updates" at my last service having specifically mentioned this issue and TBH i haven't noticed it reoccuring since. 2008 TDV6 WHITE/EBONY
| afewbeers Joined: 02 Mar 2008 Location: here and there Posts: 8
I have complained about this every time the time car has been in to the dealer for other matters (9 times now!). The gearbox has been re programmed etc but it has not made any difference.
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15236
I have had mine sorted but feel that this isn't the solution to everyones problems. My driveline shunt was huge but I have now had the rear drive shafts replaced and my RRS drives like new again. |
| All times are GMT |
Staying - Epsom Green Defender 90 for playing off road
