Home > Technical > Diff noise! |
cowey101 Member Since: 17 Jul 2007 Location: Gods country! Posts: 403 |
I have noticed a loud noise and also a jerking motion whilst applying the accelerator over the last couple of weeks. I had a similar problem with my E46 M3 and after several visits to my local BMW dealer with no satisfaction, it finally broke. The diff was totally F d! and when BMW towed my car and repaired it they said the loud banging noise was the diff on its last legs, and it finally gave up. A new diff was fitted and my car had only covered 25k
Mon Jul 21 2008 4:20pm |
Hi Josh, im off for a weeks holiday tomorrow so when I get back il see what I can find out about VIN numbers/year etc Java Black TDV6 HSE - Java Grandes Marques 1/18 - Ducati 749s |
Tue Jul 22 2008 1:36pm |
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 |
mmm, interesting... LR insisted that my Diff was replaced by the dealer despite them saying it was the transfer box. It was teh transfer box http://www.rrsport.co.uk/forum/topic9684.html GONE** RRS 3.0SC Silver fully loaded - 2020 110 loving it
Thu Jul 24 2008 6:44am |
looking throughthe forums, looks like this is going to be the next common one, can we get it "sticke'd" below the knocking? GONE** RRS 3.0SC Silver fully loaded - 2020 110 loving it
Thu Jul 24 2008 6:47am |
Done
Thu Jul 24 2008 9:14am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
I had the front diff replaced last month on my 06 HST, and there was someone else in the garage at the same time having his done too. Was told the problem were leaking seals. My car still knocks occasionally when shifting gears; used to think it only happened in and out of 1st, but the other weekend it made a huge bang when trying to downshift. Probably gearbox though and not diff.
Tue Jul 29 2008 7:12pm |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
Which models or VIN #'s are affected by this recall? PJPR
Tue Jul 29 2008 7:49pm |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 |
can only hope this is the exception rather than the rule SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
Wed Jul 30 2008 8:24am |
Japseroony Member Since: 06 Feb 2008 Location: At home with a beer!!! Posts: 256 |
Mine is in at the stealers for what they say is a "transmission noise"
Fri Aug 01 2008 10:14am |
Well things just get better and better or should that be worse and worse LR have just called me and said they have given permission to replace the transfer box - not the transmission. Correct me if I am wrong but these are two seperate components aren't they with one being the actual gearbox and the other the transfer box The stealer has now said that they replaced the oil in the transfer box and not the tranmission as they insisted yesterday Is this some intervention from LR to replace the transfer box (a much cheaper item than the transmission) and not the transmission I will be listening for any kind of noise when I get it back and making big noises at LR if there is a slight squeak "UNDERSTEER" ----is when you hit the fence with the front of the car. "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
Fri Aug 01 2008 2:54pm |
So...is there actually an official recall or is there a TSB (Technical Service bulletin) associated with this problem. If so, could you share it? Thanks. PJPR
Fri Aug 01 2008 4:59pm |
I'm not sure this actually includes the RRS.... there's definitely an Assurance Programme ongoing for the FFRR about the transmission, but I didn't think it applied to the RRS.
Mon Aug 04 2008 8:16am |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
That's what I was shown a few weeks ago. FFRR only. TDV6 - gone TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
Mon Aug 04 2008 8:54am |
There was a Service Action Bulletin issued late 2006 concerning "Rear Differential Oil Contamination".
Mon Aug 04 2008 10:05am |
