| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Off Topic > Home Cinema Speakers |
| 2nd Rower Joined: 12 Nov 2007 Location: VIC Posts: 374
Time to call on the wide knowledge of this group...
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 20861
I was Chatting to Kaine not so long ago about having some ceiling speakers fitted part of and full home audio system. Kaine said maybe i should go for these http://www.yamaha-uk.com/sound_projectors/ save cutting up all the wall and half the ceiling to fit these speakers
Thanks Jay....
Yeah i know not sure myself as i've not herd them but they do win a lot of stuff from the Mag's and that so they must be good?
| KiwiRRS Joined: 22 Aug 2007 Location: Wellington Posts: 30
Paradigm do some really nice speakers in wall/ceiling at a very reasonable cost (less expensive then bose and much fuller sound). They should be available in reasonable audio shops - probably not Harvey Norman though. Check their web - www.paradigm.com |
| AlsaaMike Joined: 26 May 2005 Location: West of the Westoplex, TX Posts: 39
Just got the Yamaha YSP4000 and installed it yesterday. It is awesome, altho' I will probably add the matching sub shortly. Have a really akward room where traditional surround speaker placement would have been a challenge without getting into the walls. Also, nice to have the amp built in, so all you see is TV and speaker bar. 2006 RRS HSE 4.4, Zambezi Silver
Connected my DVD player and Sat. T.V. receiver, and should be able to connect 2 more components. It has its own radio tuner and amp built in. Also has the ability to connect with an IPOD dock and Sat. radio. Using an entertainment wall unit so all wires are concealed. Did not see the unit at any store, but bought on the strength of several very positive online reviews. Very pleased so far. 2006 RRS HSE 4.4, Zambezi Silver
| Kaine Site Sponsor Joined: 26 May 2006 Location: Hills of Shropshire Posts: 7109
The YSP technology is very good - I run an original YSP1 at home, plus spec and fit all the new YSP's when the application doesn't really allow for cabling. HOWEVER, if cabling is possible, then the YSP isn't the best option. The surround sound effects are virtual and are very dependant on the room shape and acoustic's - if your used to a good 'defined' surround sound image then you probably wont be that impressed, however if your used to a budget surround sound setup then the YSP is excellent.
re: BOSE
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 1173
There is only one website you need:
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20671
Who needs an iPhone when you can have the Serenata!
| BKHK Joined: 05 May 2008 Location: Melbourne/Sorrento Posts: 125
2nd Rower
| All times are GMT |
