Home > Technical > Supercharged Starting Problems
whiteman
Australia 2007 Range Rover Sport Supercharged Java Black
Are any other forum members having problems with starting their RRS SC from cold.
Our 07 build SC starts very reluctantly from cold, even in Brisbane, Australia. It sounds as if only one or two cylinders catch and has to be turned off, and left for some time before it can be coaxed in starting and running properly.
The dealer, Southside Landrover, recently had the car back in to change the fuel pressure sensor and relay, following discssions with Landrover UK, but this has not solved the problem.
We have been informed that many other RRS SC have the same problem but, having serached this forum, I cannot find others in a similar predicament.
Any advice would be much appreciated!
Post #175309 Fri Jul 04 2008 6:16am
Bobby
Sometime back there was an issue with "the vehicle is difficult to start if it has been left standing for between 2-5 hours, or that the idle quality is poor for a short period after starting".
Updating the engine control module software solved the problem. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #175318 Fri Jul 04 2008 7:01am
PauloAmore
Scotland 2006 Range Rover Sport Supercharged Java Black
Some SC's have a problem caused by a low battery on startup from cold. Low power due to the cold overnight....
- Revs dip very low and she chugs away a bit. Could it be that?
Soluition - a new battery. Range Rover Sport SC - Java / Tasmods / Skirts
Morgan Plus 8
Post #175326 Fri Jul 04 2008 7:46am
