Home > Technical > BRAKE WEAR SENSORS
P44RY C
BRAKE WEAR SENSORS
Hi all, my first post.
Need some assistance if anyone knows how the hell i turn off the annoying beeping due to my brake pad wear indicator coming on on Sat!! its driving me mad now everytime i touch the brake.....can anyone help?!
many thanks
Paz
Post #174917 Mon Jun 30 2008 5:05pm
R33
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Change the brake pads! Wink
Post #174919 Mon Jun 30 2008 5:13pm
P44RY C
Laughing thats the next step, but until then, i have gotta get this indicator sorted, either that or i am going to have to buy a death metal CD and play it at full volume
Post #174920 Mon Jun 30 2008 5:15pm
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Option 2 is to take the wheels off and gut the wire to the sensors. Option 1 is however your best bet!
Apart from the 2 options mentioned there's not alot you can do as I believe tht removal of the fuse affects other important things. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #174921 Mon Jun 30 2008 5:40pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Just use the electronic parking brake to stop! Just kidding. The sensors are probably designed to be annoying on "purpose" - when activated it means your pads are worn down to almost nothing - less than 5% left I think - and you need new ones, pronto. But I also had to put up with that damn chime every time I touched the brakes not long ago in L.A. stop-and-go traffic, so I know what you mean. Very Happy I wish they had designed the sensors to activate some sort of steady "Brakes Fault" red light in the instrument cluster - which would extinguish only after the sensors were replaced with new ones, since once triggered they are no good anyway - instead of the "Ding! Fault - Oh, Never mind - Ding! Fault - Oops, My mistake - Ding! Fault" routine...
Post #174939 Mon Jun 30 2008 7:35pm
MAW
From memory ( i have just done mine) once on the edge of wearing and when the sensor is worn (shorts) the intermittent ding stops as the warning is permanent...
So brake harder quick for a while then the frequent dings will stop - but of course dont forget to do them otherwise the annoying squeal follows along with a higher bill !!!
I had about 3mm on the front left and around 5 mm on the rear when the first sensor shorted out....
Post #174958 Mon Jun 30 2008 9:58pm
P44RY C
Its is proper annoying. I replaced my Porsche Cayman with this RRS and so far am loving it, but this sensor crap is really annoying me.
Post #175001 Tue Jul 01 2008 10:07am
MAW
Involves brake pad change some time....
£110 ish DIY - £330 ish Stealer...
Post #175051 Tue Jul 01 2008 10:00pm
Yeah, much safer and easier on your ears and mental state if you just go and get them done Very Happy
In the meantime, I have a few Slayer CDs you can borrow Thumbs Up
Post #175086 Wed Jul 02 2008 8:35am
