| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Maintenance & Modifications > Not sure if this has been discussed before, is there a way.. |
| FAT_RRS Joined: 18 Jun 2008 Location: COLORADO Posts: 60
I want to disable the ride hieght control speed sensor. Sometimes, I'd like to ride around at off-road height, but if the car goes over 25mph, it lowers. Same with access height. I can see why they are limited for saftey reasons, has anyone found a way to disable the sensors? I really like to be up high sometimes on the highway.
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15232
No solution. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
oh, man!!! |
| EX-X5! Joined: 24 Sep 2007 Location: Midlands Posts: 237
If you affix a large enough object under the relevant sensor underneath, the vehicle will think its 'bottoming' out and actually go even higher than off road mode. A large barrell lashed in place with rope might do the trick. Could work? |
| npinks Joined: 26 Nov 2007 Location: Leeds Posts: 944 |
check out disco3, the Australians where looking at the opposite Higher ride height due to those bumpy roads they need to drive down |
| Alicatt Joined: 11 Jun 2007 Location: Eating in Eksel or Working in Wick Posts: 760
also check Matzkar in Germany they do a module that can raise or lower the car.
| XXXAngelXXX Joined: 03 Mar 2006 Location: assimilated....... by the Britts - since 1995 ! Posts: 5443
Matzker is the way to go |
| Supertrotter Joined: 10 Mar 2006 Location: Toastier than a toasty thing...in a toaster Posts: 8140
Angel, I thought all things made in Germany were crap... |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20732
| mazhall Joined: 01 Jul 2008 Location: caithness Posts: 2
have a look at chelsea harbour motor compony thay have softwhere for this |
| John @ DW Site Sponsor Joined: 07 May 2008 Location: Wirral Posts: 105
We sell H&R lowering modules at Designer Wheels. Unlike fooling the suspension into staying at access height which is not deisgned for use at speed, the H&R module changes the dynamics also so it rides well and handles better. These are easy to fit at home, costs £1240 inc VAT & delivery (£1375 RRP) and lowers by 30mm.
| Pelyma Joined: 28 Sep 2005 Location: Clymping, Sussex Posts: 1145
I think they want to raise the car not lower it. Like Npinks said look on D3 the Aussies cut one of the suspension rods which makes the normal height off road height (if that makes sense) DS3 TDV6 HSE
I believe you can raise the height of the off road setting using Autologic, in fact I think you can alter the height of any of the settings. If I remember rightly you can get upto an extra 25mm of height on the off road setting. Give to your local Autologic dealer a bell and I think they should be able to sort you out (so to speak!). |
| Leo Joined: 17 Sep 2007 Location: Nomad Posts: 161
The problem is not with off-road height, it's the fact that the car lowers itself at about 40mph that causes us problems. However, if we could raise the normal setting via Autologic, that could be useful. |
| All times are GMT |
