| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Off Topic > EXCEL SHEET RECOVERY - HELP |
| Kaine Joined: 27 May 2006 Location: Hills of Shropshire Posts: 6602
Thank you Cornelius - bookmarked for future reference |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: I'm having the best day of my life, and I owe it all to not going to Church! Posts: 19749
Wasn't aware of those either Cornelius, have you had any experience of using these? In my experience I haven't had much luck with these tools. |
| npinks Joined: 27 Nov 2007 Location: Leeds Posts: 648 |
A computer at the office has decided to give up the ghost and blow its motherboard (so i am told by a computer tech)
| 2nd Rower Joined: 12 Nov 2007 Location: VIC Posts: 202
It's been some years since I was a 'hands on techie' - Is the HDD being installed into the new machine as a primary or secondary hdd?
I'm not sure, i presume the PC tech is placing it in a cradle as a second machine.
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 835
If he is simply trying to retrieve data from the HD, then he needs to add as a secondary drive on a healthy PC. Simple.
Well if the new machine boots without the HDD from the dead machine connected then the rules of elimination tell you that the new machine is okay.
Depends what type of disk it is... he shouldn't forget that IDE/PATA/SATA all work differently from each other and have different interfaces, and as such have different methods for making the disk available on another machine. By rights, unless the filesystem is encrypted there's no reason why you shouldn't be able to connect it to another machine and access everything that was on there before, presuming you have the right controller to connect it to.
Well the engineers still working on it ..........and ordering the new machine etc
Many moons ago we had a YTS trainee in working with us and there was a load of PCs that needed to be moved from one floor to another. He was complaining that he was going to do his back in (in the days before health & safety got in the way of everything and a PC weighed 400 tons), so we suggested that to make his life easier and the PCs lighter to carry, that he delete all the data off the hard disks because the fuller the hard disk, the more it weighed |
| Supertrotter Joined: 10 Mar 2006 Location: Freezing my spuds off in Blighty (For a few weeks anyway!) Posts: 7218
