| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
| NIM Joined: 02 May 2008 Location: TORONTO Posts: 7
COULD YOU GUYS GET YOUR DEALERS TO REPLACE THE BUSHINGS ON THE ARC UNIT THEY ARE JUST LIKE THE SWAY BAR BUSHINGS , I HAVE HAD A LOT OF RR SPORT WITH THIS FAULT, AND ALSO LET THEM REPLACE THE NUTS ON THE SWAY BAR LINKS AND MAKE SURE THEY ARE TORQUE TO 75 FT LBS, I HAVE HEARD THE NOISE AND THIS SEEMS TO FIX IT THANKS NIM. HELLO EVERYONE,I HAVE BEEN WITH LAND ROVER FOR THE LAST 15 YEARS AND HAVE A LOT OF EXPERIENCE WITH THIS BRAND, IF ANYONE NEED ME TO ANSWER A QUESTION OR 2 DO NOT HESITATE TO
| chris Joined: 27 Aug 2006 Location: south Posts: 31
Hi Nim,
| Josh Joined: 24 Dec 2005 Location: Here, there and everywhere Posts: 1440
Hi guys, another fault is that i saw a mechanic work on a vehicle for 2 weeks and when i got the rr sport i figured that the line was not spaced in the mounts properly, and it was causing the noise, if your dealer activate the arc system it will make the noise in the shop and they will be able to better diag the problem.Thanks Nim. HELLO EVERYONE,I HAVE BEEN WITH LAND ROVER FOR THE LAST 15 YEARS AND HAVE A LOT OF EXPERIENCE WITH THIS BRAND, IF ANYONE NEED ME TO ANSWER A QUESTION OR 2 DO NOT HESITATE TO
| weim71 Joined: 07 May 2008 Location: Scotland Posts: 9
Hi Guys,
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: I'm having the best day of my life, and I owe it all to not going to Church! Posts: 19749
Definitely not normal, as the countless posts on here will confirm. The fact that it's "normal" seems to be a LR party line. |
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 835
Unbelievably, my stealer is on his 4th attempt at rectification (slightly dirty word |
Car got recovered yesterday on LR assistance advice.......suspension was making a hell of a noise. It sounded like something had worked loose on top of the normal knockety knock noise!!! |
Oh jesus thats awful!
I think that's the issue........LR don't seem concerned or are loathed to get involved in any of the situations. The dealers seem to be the ones trying to find the resolution, but there is no definitive......it is absolutely crazy and pitiful to think that as much as we are now celebrating the RRS 3rd birthday - this |
| plum Joined: 16 Sep 2007 Location: Heptonstall Posts: 39
| Leo Joined: 17 Sep 2007 Location: Nomad Posts: 94
Car returned and all is well again. Apparently the 75Nm torque setting as discussed here previously, worked itself loose |
Well, i hope that has fixed it and there's no more knocking. This sort of thing |
