tastech
Zilch wrote:Tastetech (got a first name)/Anthony, i put the tyres down to 18 PSI and not a problem on the sand, i would recommend the Staun deflators, they make letting the pressure down so simple and automatically cut off at the correct pressure (or thereabouts)
Jim
Jim
Where did you end up getting those stauns from? and what was the cost?
cheers
Steve RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse
Mon May 19 2008 2:36pm |
Zilch
tastech wrote:Jim
cheers
Steve
Steve i got them from 4x4 Megastore near Hornsby, i believe any reputable 4x4 shop will sell them. Cost $79 for a set of 4. To be honest 1 or 2 will do it, as i only let 1 tyre down at a time so i could check the tyre pressures and not have to wholesale re-inflate the lot of them. Even managed to get the supercheap auto compressor working again, in the end i did not require the compressor at Stockton, there are service stations within 300 metres at each end of the beach with Air facilities yet another Pommie living in Sydney
2.7 RRS TDV6, Zermatt/Ebony moooo-hide, Clear pack, Cruise, Sunroof, tow pack, RPS, Tasmod Sills, RRS Umbrella, RRSPORT rear window sticker and last but not least a "Supercheap Auto" $20 cargo net "Marvellous"
Tue May 20 2008 11:53am |
Zilch
2nd Rower wrote:I'm about to order myself some too:
http://www.4x4store.com.au/Staun-Tyre-Deflators-pr-14441.html
those be the ones, deflated to approx 18-20 psi on preset, worked a treat yet another Pommie living in Sydney
Tue May 20 2008 12:19pm |
