| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Help. Can't pair phone with bluetooth, won't find LR device |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14186
No the cars bluetooth should be on all the time and as far as I'm aware you can not switch it off. A trip to a LR dealer is my only advise. |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 18779
Have you tried to pair another phone to the RRS? |
| joka748 Joined: 28 Nov 2007 Location: Hampshire Posts: 10
There is a different bluetooth pairing code depending if your car kit was factory fitted or dealer installed.
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 461
Also depends on what handeset you are using......some are notoriously tricky. |
| KevinJM Joined: 16 Dec 2005 Location: over and back these days Posts: 85
I have a retro-fitted LR bluetooth system - have experienced this problem twice. I disconnect (-) battery connection for couple of seconds and re-connect and the bluetooth resets itself. |
