| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Maintenance & Modifications > Tailgate gas struts |
| MAW Joined: 06 May 2006 Location: Lincs Posts: 730
.... one failed last week, anyone else had similar? Full door one side it seems, door becomes very heavy ! On backorder with stealer.... |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 20268
I know there was a problem with the struts in the early days but i think it was to do with the bolts not the gas RRS TDV6 Gone but still around
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20070
Yes, used to be a problem years ago... there was an issue with the fixtures, but also with the gas if I remember. Shortly after, they shipped a newer part and that was the end of it. |
| Endjin Joined: 22 Jun 2007 Location: Aberdeenshire Posts: 485
I've also had problems in cold weather, the struts seem to get very stiff and the tailgate needs to be pushed up, rather than just lifting itself. I suspect the struts are not gass filled but are liquid filled and the liquid becomes more viscous in the cold. Anyone had same or can confirm? Range Rover Sport - 2.7 TDV6 HSE - Java Black - Privacy Glass - Dealer Superchipped - a set of swanky TASMOD sill plates & Body Colour Matched SC Grill & Side Vents. |
Thinking about it I should have not called them gas struts - I now recall seeing an oily liquid near the seal - stealer has them now and in for fitting Monday... |
| ayates Joined: 08 Jun 2007 Location: Houston Texas Posts: 184
On the odd days it is chilly in Houston my struts get a bit stiff..... |
Was thinking that too |
