Home > Technical > Access mode
BKHK
Australia
Access mode
Is there a way to make the car always go to access mode when it is parked and the ignition is off? My handbook tells me that I can control the Air Suspension from the remote (Mrs BKHK would like it to have easier access) but to be honest, either I am being thick or it doesn't work.
Can anyone help?
Post #169556 Wed May 14 2008 2:43am
Bobby
No, there's no way.
You could manually press the switch to lower the car are you are about to stop and it will very quickly go to Access mode when you're stopped. And it will stay that way. This will help Mrs BKHK to get out and get in again. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #169561 Wed May 14 2008 5:42am
tastech
Australia 2008 Range Rover Sport TDV6 SE Rimini Red
Re: Access mode
Can anyone help?
Well i spoke about this is another posting...there is a thing called transpotation mode...
where the car actually drops to the suspension stops...after the power is off...
this is so that during transportation the car down not have free movement on its airbags to move around too much...
so he enjoyed having that functions...(cause the dealers forgot to turn it off) until he had to change the wheel
and it hung like a limp elephants you know what...he got to the end of the jack extension and the wheel was still touching the ground...
Post #169566 Wed May 14 2008 8:01am
BKHK
Australia
Hmmmm....my handbook tells me I can control the suspension from the remote?? The other functions are panic alarm and headlight delay.
When I pressed the suspension lower button at the same time as the Land Rover Button, the car beeped as it said in the handbook. The thing is, the remote seems to do nothing for the suspension.
Now, that particular key emote used to unlock the boot, now it doesn't because I tried to make it work the suspension. If I can't work the suspension from this remote for access mode, how do I make that particular remote unlock the boot again??
I hope I haven't stuffed anything up.....
Advice needed!!
Post #169570 Wed May 14 2008 8:09am
tastech
Advice needed!!
pardon the obvious,, but are all the doors closed...i know that is one of the safety things...
i got that working for my mates disco...6 months idle hands...had some time to read the manual cover to cover...
Post #169574 Wed May 14 2008 8:30am
Bobby
In the older models one could raise/lower the suspension via the remote in order to hitch a trailer... .
Not sure how this works in the newer models though. Malaysia Boleh!
Post #169578 Wed May 14 2008 8:55am
Tim in Scotland
Tastech it doesn't work on my 2008MY Tdv8. When you press the button to lower keep the button pressed until you hear the warning bong and then it will be locked in access mode until you unlock it again. This is for use in carparks with low ceilings. It you lock it down you MUST unlock it again when you drive off by holding the switch until you get the warning gong again and the message on the info screen. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #169583 Wed May 14 2008 9:11am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Also think that you have to have the hazzard lights on too before the suspension will move. Sons of dogs come eat flesh
Clan Cameron
Post #169601 Wed May 14 2008 10:21am
tastech
deleted...
Post #169604 Wed May 14 2008 10:34am
tastech
apologies alicatt you are right...the hazard lights need to be on...
Post #169606 Wed May 14 2008 10:43am
Tim in Scotland
ahhhhhhhhhhhhhhhhhhhh - will have to try it sometime then! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #169608 Wed May 14 2008 10:54am
Alicatt
tastech wrote:
mmm...i dont remember having to do that...but i think you had to have both keys/remotes programmed to the function...i think...
i know i remember reading for the lazy access to work all the remotes had to be set to lazy access mode...
(which is where the seats slide back to let you out )
I have lazy entry set to on but the seats only slide to your set possition Sons of dogs come eat flesh
Clan Cameron
Post #169613 Wed May 14 2008 11:01am
tastech
yeah...your right ...
mmm gees thats a pity...i like that way it works in other cars...
Post #169619 Wed May 14 2008 11:54am
BKHK
Australia
You guys are probably right about the hazard lights, it does say that in the handbook. I thought it was just some meaningless Health and Safety thing but maybe not. The thing is, it all seems a bit inconvenient to have to open the door, switch on the hazard lights, close the door and then adjust the suspension using the remote. While I have the door open, its easier just to hit the suspension switch...or am I missing something?
So, how do I now make my remote go back to the boot release function it had originally? I should stop stuffing around with things!!
Post #169623 Wed May 14 2008 1:21pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Can't raise or lower suspensions - remotely or not - whilst any door is open... Think the only exception may be the rear tailgate.
Post #169782 Thu May 15 2008 2:18pm
