Home > Technical > Locking wheel nuts on rrsport
exige1
United Kingdom 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Yesterday found i had a nail in my tyre.
Started to take the wheel off, put the locking wheel nut key over locking nut, turned but outer casing of locking nut just spins round.
Landrover assistance came out same problem.
The thing is, this has just had its 2nd service surely they would of had to take the rear wheels off during this?
Car is still under warranty, but will it cover having the nut drilled out etc?
Post #169586 Wed May 14 2008 9:23am
BigMart
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
LR Stealers WILL NOT remove wheels unless they absolutely have to .
The warranty should cover drilling /replacement of the stud and nut if you've got a full service history
Independent specialists like JE will still remove wheels / grease hubs etc.
I bought the wife an 06 plate audi a4 at xmas , 58k miles full audi history.
It took me 2 hours on a garage ramp to hammer the wheels off after all bolts removed. Shocked
You wouldnt want to do that by the side of the road
because the locking nut is softer than a normal nut they won't stand the force of a normal nut.
Good luck.
Mart
BTW , a relative of mine works for a nut supplier to LR....guess what ...they have recently been doing trials on wheel nuts in different grades of steel with different heat treatments and corrosion platings.
Maybe there is an issue??
Mange tout! RRS TDV6 HSE 2006 , Zermatt , Mudflaps , Steps , Privacy glass , Towbar (sometimes), Remap ,JP Stainless Exhaust
Post #169594 Wed May 14 2008 9:47am
exige1
Thanks for that, sounds interesting.
Just getting the main dealer to ring me back would be a good start.
Post #169610 Wed May 14 2008 10:56am
exige1
Well my usual main dealer said they couldn't do it for weeks. (Not going there again)
Phoned another and the car was in same day. Drilled locking wheel nut out but alloy now buggered.
New alloy and all work carried out under warranty thank god. Should pick it up later today.
Post #169842 Fri May 16 2008 11:49am
