| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Off Topic > EXCEL SHEET RECOVERY - HELP |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20400
Good luck with it... |
| Kaine Joined: 27 May 2006 Location: Hills of Shropshire Posts: 6945
Nick - this is a private client - I'm onsite at this new build project so unfortunately no IT dept - in fact I have become his IT dept today |
| cyberjes Joined: 12 Jan 2008 Location: Prague Posts: 99
R.I.P.
| Endjin Joined: 22 Jun 2007 Location: Aberdeenshire Posts: 504
Kaine, There is a facility in windows to recover previous versions of files under these circumstances. It's called "Shadow Copy Client". The only problem is, it is not activated by default but has to be configured. In the slim hope that your client may have this feature enabled try placing the mouse cursor over the file in question, right click once and look down the menu that appears. If the Shadow copy is enabled then one of the options available will be "Previous Versions" which you can then select from to recover the file. If he doesn't have "Shadow Copy" enabled then I'm afraid he's stuffed. Advise him to buy a cheap backup solution. Freecom do one for about £60 that is simply an external Hard Drive bundled with NTI backup software and works very well for Single users/small companies. Range Rover Sport - 2.7 TDV6 HSE - Java Black - Privacy Glass - Dealer Superchipped - a set of swanky TASMOD sill plates & Body Colour Matched SC Grill & Side Vents. |
Thanks mate - he's now left to go get a back up drive and has arranged for some two of his staff to work over the weekend to remake the documents
| npinks Joined: 27 Nov 2007 Location: Leeds Posts: 809 |
is the shadow copy function part of Vista or is it availaible on XP |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14938
Apple have a thing called Time Machine which rescues situations like this - now if only they made software for the Mac! |
VA - learnt about that software today - looks very good |
cheers Endjin
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 1034
Kaine,
Hi Will,
NP.
| Cornelius Vermuyden Joined: 15 Aug 2006 Location: The Far Canal Posts: 142
Kaine Contrary to comments, Excel files are pretty easy to recover, at low cost (unless some erasing 37-pass overwrite has been used)
