Home > Off Topic > EXCEL SHEET RECOVERY - HELP
Page 2 of 3 <123>
Good luck with it... Thumbs Up
Post #165974 Fri Apr 18 2008 1:23pm
Nick - this is a private client - I'm onsite at this new build project so unfortunately no IT dept - in fact I have become his IT dept today Laughing
I'm resisting the temptation to keep telling him he should have backed it all up in case I lose the contract Laughing
Post #165978 Fri Apr 18 2008 1:47pm
cyberjes
2008 Range Rover Sport TDV8 HSE Buckingham Blue
R.I.P.
Big Cry Big Cry Big Cry MY08 TDV8 HSE
Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock
Post #166018 Fri Apr 18 2008 3:04pm
Endjin
Kaine, There is a facility in windows to recover previous versions of files under these circumstances. It's called "Shadow Copy Client". The only problem is, it is not activated by default but has to be configured. In the slim hope that your client may have this feature enabled try placing the mouse cursor over the file in question, right click once and look down the menu that appears. If the Shadow copy is enabled then one of the options available will be "Previous Versions" which you can then select from to recover the file. If he doesn't have "Shadow Copy" enabled then I'm afraid he's stuffed. Advise him to buy a cheap backup solution. Freecom do one for about £60 that is simply an external Hard Drive bundled with NTI backup software and works very well for Single users/small companies. Range Rover Sport - 2.7 TDV6 HSE - Java Black - Privacy Glass - Dealer Superchipped - a set of swanky TASMOD sill plates & Body Colour Matched SC Grill & Side Vents. Smile
Porsche Boxster S - 3.2 - Black
Post #166027 Fri Apr 18 2008 3:27pm
Thanks mate - he's now left to go get a back up drive and has arranged for some two of his staff to work over the weekend to remake the documents
lesson learnt I think
Post #166030 Fri Apr 18 2008 3:32pm
Endjin
Yep, They always learn after the fact! People don't seem to value their data until they lose it then they panic!!
Crazy, Mad, Bonkers Rolling Eyes Especially when backup solutions are so easy and cheap these days. Whistle Range Rover Sport - 2.7 TDV6 HSE - Java Black - Privacy Glass - Dealer Superchipped - a set of swanky TASMOD sill plates & Body Colour Matched SC Grill & Side Vents. Smile
Post #166033 Fri Apr 18 2008 3:54pm
is the shadow copy function part of Vista or is it availaible on XP Question
Post #166061 Fri Apr 18 2008 6:13pm
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Apple have a thing called Time Machine which rescues situations like this - now if only they made software for the Mac! Rolling with laughter RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #166071 Fri Apr 18 2008 7:25pm
VA - learnt about that software today - looks very good
Post #166073 Fri Apr 18 2008 7:27pm
Endjin
Yep It's available in XP. Just search for it using google and you'll find loads of help sites that talk you through activating it. Remember - GOOGLE is your friend Thumbs Up Range Rover Sport - 2.7 TDV6 HSE - Java Black - Privacy Glass - Dealer Superchipped - a set of swanky TASMOD sill plates & Body Colour Matched SC Grill & Side Vents. Smile
Post #166177 Sat Apr 19 2008 1:41pm
cheers Endjin
I posted on here and googled it afterwards, so will have a good luck on monday when back in the office Thumbs Up
Post #166194 Sat Apr 19 2008 6:10pm
will_wonka
United Kingdom 2006 Range Rover Sport Supercharged HST Rimini Red
Kaine,
All is not lost. There are 2 things to try, one or the other should work. Not sure if you are using Office 2003 or 2007, either way, it works basically on the same principal.
Firstly. In Word, there are many options, of which many are switched on by default. Autosave being one of them.
Look here for the doc name:
C:\Users\Will\AppData\Roaming\Microsoft\Excel\
Check this location 1st.
If that fails, the 2nd option is to look in the "temp" directory: C:\WINDOWS\Temp
If that fails, I can provide a Freeware recovery piece of software, but that will only work if the sector on the disk has not been re-written too. If that has happened, you are 100% snookered - recovery specialist or not. Big Cry [/img] My Gladiators:
RRS S/C HST - respect of the highest order
Freeloader 2 SE with all the toys - my baby RR
Merc SL55 AMG - Tarmac ripper!
Disco3 - Gone
Defender 90 TD - Gone
FFRR Vogue - Gone
BMW X5 4.4 - Gone
LR Defender 300Tdi - Gone
LR Defender 2.5 PETROL - Gone
Post #166289 Sun Apr 20 2008 7:46pm
Hi Will,
Thanks for your post, but its too late. The problem was a clients problem on Friday and as we were unable to resolve it then so the file is being recreated from scratch to his frustration.
Thanks
Post #166294 Sun Apr 20 2008 8:31pm
will_wonka
NP.
Any other time, only too happy to help!! Thumbs Up My Gladiators:
Disco3 - Gone
FFRR Vogue - Gone
BMW X5 4.4 - Gone
Post #166326 Sun Apr 20 2008 9:51pm
Cornelius Vermuyden
Kaine Contrary to comments, Excel files are pretty easy to recover, at low cost (unless some erasing 37-pass overwrite has been used)
Check out http://www.easeus.com/datarecoverywizard/r...-files.htm or
http://www.whitecanyon.com/recover-deleted...-files.php
This, or similar, is what the data recovery people will use, at greater expense! Confused
Post #166338 Sun Apr 20 2008 11:23pm
Page 2 of 3 <123>
