| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Seat position - AGAIN!! |
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 445
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: Me fail English? That's unpossible. Posts: 18511
It is quite baffling.... surely all the seats go into the cars the same... have the same components, the same movement ranges on the seat motors etc.
| Jonny Fresh Joined: 04 Feb 2008 Location: Manchester Posts: 185
Maybe its not your height, nor the leg/torso proportionality but moreso the manner in which you seat yourself.......try sitting with the seat as low as possible (obvious!), the front tilted up slightly, and put your backside as far back in the seat as possible, vary the tilt until you find it comfortable. |
Or.... you could cut a hole in the sunroof so that you were given miles of headroom! |
When I say try tilting the seat I dont mean the back I mean the bit you sit on, that can be tilted on the horizontal plane |
Hmmm, yes I have tried that to the point where I am being crushed on the roof.....I have it in almost the lowest position, albeit it lacks support in that position"!"! |
Some people are never happy |
| 2nd Rower Joined: 12 Nov 2007 Location: VIC Posts: 141
Well, the re-engineering failed as it would have been too close to the bone and in the event of an accident.....well, you know where that would end up - non-payout.
Some news.
