| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
| plum Joined: 16 Sep 2007 Location: Heptonstall Posts: 38
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1751
Normally in the TSBs, the VIN-range will only show the actual 'serial number' and does not include the MY.
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 597
well, after only 3000 miles...the knocking has returned....again!
| Josh Joined: 24 Dec 2005 Location: Here, there and everywhere Posts: 1411
I had a FNS lower ball joint replaced yesterday, new tyres and 4 wheel alignment. They said there was excessive movement in the joint which was causing the noise.
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: Me fail English? That's unpossible. Posts: 19077
Good luck Josh - let us know |
Silence is wonderful |
| sid Joined: 21 Aug 2007 Location: northants Posts: 42
Hi josh,
| Kaine Joined: 27 May 2006 Location: Hills of Shropshire Posts: 6230
Great News Josh |
| chris Joined: 27 Aug 2006 Location: south Posts: 28
Hi Josh,
| Nutty Nige Joined: 21 Feb 2007 Location: Staffordshire Posts: 330
Well actually no Chris, that is a bit harder.
Re the dynamic response knocking, would it be helpful to confront the dealer with this...?
Well my own IDS says its done but now I have the TSB I can check properly on the download number
