Home > Maintenance & Modifications > NAV.TV
lemm
2005 Range Rover Sport Supercharged Vesuvius Orange
NAV.TV
i fitted a NAV.TV unit over the weekend and i just thought i would let you all know its very easy to install...
once you get past the removal of the interior parts to gain access to the NAV screen, its very simply. (Big thanks to Bobby's PDF's Thumbs Up ) The most difficult bit is remove the side panels so you can remove the vents either side of the screen...
to give yourself a headstart... work out where you will tap into 12V power & ground, I was OK as i tapped into the feed supplying my DVD (located inside the upper glove box).
follow the instructions supplied by NAV.TV... pausing to double check you are creating the fibre loop in the correct direction. At the end of the installation you are left with composite audio (L&R) & Video... plug in to any source and hey presto you have TV/DVD/Playstation/iPod displayed on the front screen.
Note: if quality of picture is poor, change channel using onscreen options... wasted some time yesterday trying to work out why the quality of the picture was Censored , only to find changing channel (on NAV Screen) gave me a perfect picture.
Current setup has my TV Tuner (ALPINE TUE-T200DV) output connecting directly into the NAV.TV input... and then AV1 on the TV Tuner connects to the DVD Player. ie. to watch DVD, i simply select AV on the TV Tuner Remote.
Next step is to add 'x' ipod module into AV2 on the TV Tuner which should allow for music & video to be played on the front screen (and 2 rears) from my iPod. RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, DVD, NAV.TV, Stormer Alloys.
Post #162591 Mon Mar 31 2008 10:45am
Nice one, lemm.... a photo journal of the install would have been good, maybe you could look at doing this for your iPod install? I'm sure loads of people would be interested to see such a thing Thumbs Up
Post #162593 Mon Mar 31 2008 10:50am
lemm
that was my original intention... but alas the weather didn't hold up (photo's looked Censored with dark skies). I'll defo put something together in the summer when the pictures will be clearer... RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, DVD, NAV.TV, Stormer Alloys.
Post #162597 Mon Mar 31 2008 11:02am
Thanks mate Thumbs Up
Post #162600 Mon Mar 31 2008 11:06am
NickM
Lemm, straight up, any chance I pay you £250 you could do mine for me - plus all the necc hardware/ cables etc of course - been looking to get this done for a while - even just the DVD would be great......think about it and let me know 2007 RRS TDV6 HSE JAVA/EBONY SIDE STEPS, REAR GUARDS. 22'' STORMER WHEELS. FULL COLOUR CODE. SMOKED SIDE LIGHTS
Post #162743 Mon Mar 31 2008 1:47pm
lemm
ummm...could be a nice little earner on the side.
Only issue i have is i don't yet have a 100% way of removing pieces of trim with the potential of breaking things. Method at the moment is to pull quite hard and cross fingers. my method is fine on my car... on someone else's... ummm. Must be something i am doing wrong... looking at the clips i can see how they are pushed into place, just can't work out a safe way of removing it.
NickM, Let me do some more investigation and i will come back to you... RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, DVD, NAV.TV, Stormer Alloys.
Post #162875 Mon Mar 31 2008 9:15pm
NickM
thanks mate Thumbs Up 2007 RRS TDV6 HSE JAVA/EBONY SIDE STEPS, REAR GUARDS. 22'' STORMER WHEELS. FULL COLOUR CODE. SMOKED SIDE LIGHTS
Post #162877 Mon Mar 31 2008 9:19pm
lemm
now where's Bobby when you need him... other than Bobby's personal PDF library, anybody have any idea as to the correct technique to removing internal trim???? RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, DVD, NAV.TV, Stormer Alloys.
Post #162878 Mon Mar 31 2008 9:28pm
Bobby
sorry lemm, the PDFs only what I've got. Have not done it myself so no idea on correct technique. Sad
Lateral5 should have gone through this path but he seems to have disappeared... Rolling Eyes Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #162884 Mon Mar 31 2008 11:54pm
gadgetJunky72
2005 Range Rover Sport TDV6 HSE Java Black
maybe these might help...
http://www.ipodcarkitdirect.co.uk/Trim_Removal_Tool_Set
Post #162904 Tue Apr 01 2008 9:03am
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
lemm - what was the cost of the whole install? RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #162907 Tue Apr 01 2008 9:36am
NickM
Good Q - will make me decide between getting a TV Tuner and DVD - or just a DVD 2007 RRS TDV6 HSE JAVA/EBONY SIDE STEPS, REAR GUARDS. 22'' STORMER WHEELS. FULL COLOUR CODE. SMOKED SIDE LIGHTS
Post #162941 Tue Apr 01 2008 1:47pm
lemm
NAV.TV = £440.98
Alpine TV Tuner = £349.99 (reclaiming this cost back from the LR Dealer... car was sold with a tuner which wasn't installed, previous owner must have taken it with them)
DVD = around £150 (came with car so don't know exact price)
NOTE: its also worth pointing out you could install the NAV.TV unit on its own leaving 3 x phono sockets in a readily accessible place to which you can connect your own kit (ie. PS2,Xbox,Portable DVD Player)
these might just work... let me order some stuff and i'll see what works best. By the look of one of the pieces, simple knife (blunt) might do the trick RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, DVD, NAV.TV, Stormer Alloys.
Post #162980 Tue Apr 01 2008 3:38pm
lemm
i've ordered a trim removal tool set which should be here for the weekend... i'll have a play and see if it makes the removal of trim any easier. RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, DVD, NAV.TV, Stormer Alloys.
Post #163193 Wed Apr 02 2008 5:32pm
NickM
Lemm and I'm your first customer right??? At the very least can you hook up a DVD player to the front screen??
Thanks mate Thumbs Up 2007 RRS TDV6 HSE JAVA/EBONY SIDE STEPS, REAR GUARDS. 22'' STORMER WHEELS. FULL COLOUR CODE. SMOKED SIDE LIGHTS
Post #163209 Wed Apr 02 2008 7:46pm
