Home > Maintenance & Modifications > anyone did a remap in Barcelona Spain?
Page 2 of 3 <123>
chelseaharbour
There is plenty more scope for more torque to be put on the map on any diesel. All manufuctures lay out a perimeters for tuners to work within as long as you stick below their thresold there will be no harm to the engine. Yes you may get engine wear a tiny bit more but it just means you have to service and look after your car a bit more like any engine that is working harder. It just means you have to be aware of your oil levels maybe a month before you normally check. But harm to the engine I haven't heard of it! Remember remapping is making the engine drive like it should, smoother gear changes, less lagg at the bottom end and more importantly to acheive a fuel save, less revs = fuel save.
regards
darren
Post #160426 Tue Mar 18 2008 12:19pm
View user's profile Send private message Send e-mail Reply with quote
boyd
2005 Range Rover Sport TDV6 SE Adriatic Blue
Pete from bellautos....Ive PM them but no answer...saw you edited yr message today PM them again with this address and lets hope I can get an answer soon...thanks again!
Post #161097 Sat Mar 22 2008 10:05pm
bellautos
Site Sponsor
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
I will send him a email now see if i can get an answer.
Failing that , make a trip to ricardo@jcf4x4.es in Malaga ,Spain 0035 606403401
PM me your chassis number or registration number and ill make sure you get a very good deal/price for driving the length of the country.
Post #161098 Sat Mar 22 2008 10:08pm
boyd
thanks a lot pete ...but Malaga is about 1500 km away from Barcelona...
thanks again for trying to help me out!
Post #161099 Sat Mar 22 2008 10:23pm
bellautos
Site Sponsor
Ahh , a bit to far to drive then Sad
Ill see if i get a email back from the other person, he is not my dealer only another garage local to you i know, so i have no control over him regarding booking as such.
Ill do my best to help get you sorted asap.
Regards Pete
Post #161100 Sat Mar 22 2008 10:24pm
Cornelius Vermuyden
@bellautos The TDV6 RRS 6-speed auto box does NOT have a maximum torque capacity of 472 Nm input. I have explained all this in a long post elsewhere which I can't be bothered to look for.Suffice it to say the TDV6 has the First Generation 6HP 26 box, or at best the hybrid 6HP 26A box, both of which are rated at 600Nm input. It does not have the 6HP 32, much less the 6HP32 A rated at 750 and 770 Nm respectively. Neither does the TdV8 which produces an LR stated figure of 640Nm so LR must think there is a very considerable safety margin Smile
FYI
    speeds
    Product (forw.) Input torque(Nm)
    5 HP 19 5 300
    5 HP 24 5 420
    6 HP 26 6 600
    6 HP 26 A 6 600
    6 HP 32 6 750
    4 HP 20 4 330
    5 HP 19 FL 5 310
    6 HP 32 A 6 770
Last update: 2008-01-13 - Responsible:P-PR ZF Friedrichshafen AG
Rather than replacing the 1st generation 6HPs, the 2nd generation versions will be built alongside them at the Saarbrucken plant in Germany, effectively as a higher cost option, to those vehicle manufacturers that can afford to pay more for improved performance. Therefore, it would have been most unlikely to see the new versions appearing on any of the Ford Group applications. TaTa will be a different story so prepare to get used to EIGHT gears Wink
Post #161102 Sun Mar 23 2008 1:34am
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I guess its not the engine or even gear box that comes under the biggest extra stress following a remap. Its probably the Turbo unit.
I spoke to a Ford Engine Development specialist about this a few months ago. He (perhaps not surprisingly) was very negative about remaps. He explained how Ford use millions of pounds worth of specialist equipment and 1,000's of highly qualified man hours to develop the "optimum" tune to play on an engine. As he sees it, someone with nothing more than a PC comes along and alters the program and then claims to have achieved something better than the original team achieved. And when asked if a remap might create problems, he said it was quite possible that the wear and tear on the Turbo Charger would increase substantially as the remap would be asking that unit to spin faster and longer than the original state of tune.
Now I can easily see how Ford tuners build in good margins for error in their set ups, so as to reduce the risk of big warranty claims and enhance longevity, so a retuner is simply eating into this margin for error to squeeze more go from the same unit.
As such, my policy is to respect the retuned unit, and take particular care of the Turbo by allowing cooling down and slowing down time before switching off the engine and only using the best oil, always at the right level and changed every 7,500 miles. Results are Razz all around. RRS TDv8 HSE Rimini
Disco 3 TDv6 HSE Tonga
Defender 200tdi, CSW, a mint, red one (can mint be red ?)
Post #161105 Sun Mar 23 2008 8:09am
bellautos
Site Sponsor
Cornelius Vermuyden wrote:
@bellautos
i stand corrected .
I thank you for correcting me on this matter.
Post #161109 Sun Mar 23 2008 11:52am
Cornelius Vermuyden
np Peter, I am notorious at work for having told a Defender owner it would take 2 weeks to do a Stage 2 upgrade! Laughing
Smarticus is totally correct. If there is to be a weak link it will be the turbo and S's 30sec wind-down after a blast before switching off is a very good practise. Also slavish adherence to oil-change/top up. I won't recommend a make of oil other than to say I have always used Motul oils in my race and road cars, even when sponsored by Shell!! That could be the start of a new thread Very Happy
Post #161140 Sun Mar 23 2008 4:41pm
boyd
I contacted Pete from Bellautos and he arranged me an ECU tuning ...right here in Spain Barcelona
Awesome and serious people to work with! Aswell as Ricardo (spanish guy) who worked with Pete through the reading/programming process
My car responded great aswell ,very happy with the extra Hp ..it feels like over 40 HP more....do not know about the real figures.....definately a great choise!!
Thanks to Pete from Belleautos and thanks to Ricardo from Rumbo sur 4x4
Post #165539 Tue Apr 15 2008 8:35pm
bellautos
Site Sponsor
Hi
Im glad your happy m8,
The last car that had the exact same software revision as your car i had on a Dyno Dynamics dyno made 42bhp and 88nm only 4 or so weeks agao. "Yes more is possibile , but as you feel no more is needed" Smile
These are the figures id expect you to get considering your car is the exact same revision.
How is the speed limiter going ? Did i hit the speed demod on the head with this one ?
Regards pete
Post #165540 Tue Apr 15 2008 8:45pm
boyd
hey Pete,still not know about the speed limiter as the max speed allowed by the government is 80 km/h and on the highway 120 km/h... still could not pick a decent highway without cameras to check..will let you know!
rgds
Post #165546 Tue Apr 15 2008 9:40pm
bellautos
Site Sponsor
Hello Boyd, just a chq up on how your car is running,fuel consumption and your speed limiter.
Please if you have time can you post a reply with your cars resuslt.
Regards Pete
B-A-S Remap Switch available, Giving you control over your remap.
Post #169680 Wed May 14 2008 10:10pm
boyd
Hey pete,the car is running great...couldnt check for the speed limiter yet... will let you know asap
Post #169815 Thu May 15 2008 9:23pm
bellautos
Site Sponsor
Hi
Im glad you and the car are both happy Smile
Let me know on the speed limiter when you have change totrythe setting i gave you .
Regards Pete
Post #169826 Fri May 16 2008 8:13am
Page 2 of 3 <123>
