| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > General > Does anyone else get a driveline shunt at low speeds?SORTED! |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14147
I have this and I'm told it's a characteristic - which obviously is b |
| ChrisP Joined: 26 Jan 2008 Location: Derbyshire Dales Posts: 85
Diablo,
Would also be interested to know age of these cars.
| Diablo Joined: 28 Jan 2008 Location: UK Posts: 29 |
VA,
Just got off the phone to a tech at the supplying dealer. He said that this is a known problem and there is a cure. They double flush the gearbox and then update the software in the engine, gearbox and transfer box ECU's. I am now going to ask my local dealer if he can do the work under warranty. |
I had this done but it didn't sort the problem out. |
Oh! Let me see what my local dealer says. |
| 2nd Rower Joined: 12 Nov 2007 Location: VIC Posts: 141
I get something similar to this sometimes as as I pull the car to a stop at traffic lights. The car shunts /slightly jolts forward. I assumed this was normal?! |
| Murdered out Joined: 08 Feb 2008 Location: Arizona Posts: 70
around 145 MPH i get a little vibration.
| afewbeers Joined: 02 Mar 2008 Location: here and there Posts: 5
Have the same issue on my 06 HSE. It was recently inspected by a technical rep from LR, unfortunately I was not there but it was declared as acceptable and they will not take further action.
| boffb0 Joined: 31 Mar 2008 Location: London Posts: 13 |
Folks
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 449
I too now get this and also used too on the D3. The D3 is now sorted - LR applied an update patch to the gearbox. Must be one of those contagious issues as the D3 normally sits beside the RRS on the drive, and the RRS never used to do this, however, it does now!!! |
| Evolved Joined: 12 Mar 2007 Location: Caribbean Posts: 35 |
I also get this problem...
| Jonny Fresh Joined: 04 Feb 2008 Location: Manchester Posts: 185
