Home > Maintenance & Modifications > 4wd trip preparation
dukemasterpro
Australia
I'm planning on going on a 4 day 4wd trip in Snowy Mtns, NSW Australia.
Have been advised to bring the following spares for the trip:
We recommend that you always carry spare radiator hoses, fan and air conditioning belts, fuel filter, 5 litres of engine oil, 1 litre of differential and gearbox oils and 1 litre of brake fluid. A spare air filter is also a good idea and include a selection of spare fuses
Is there anything else a TDV8 sport might need? Any comments on the above list also would be helpful to save carrying anything that is not technically relevant to this car.
Post #159684 Fri Mar 14 2008 2:13am
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
A good floor jack (as opposed to the crappy one provided by LR), and base in case you are on soft ground. How good is your current battery? Nothing like a dead battery in the middle of nowhere to cause a problem...maybe a spare.
Good quality Air compressor, tire repair kit, 5 gallons of water per person, 5 gallon diesel can, recovery equipment (snatch straps, d shackles etc, shovel, flashlights or lanterns, 2 pairs of gloves, plastic bags to throw muddy clothes, etc. etc.
Tons of sites on Overlanding or Expeditions can give you good ideas on how to be self-sufficient.
Sounds like a great trip...share some pictures afterwards! Very Happy PJPR - 06 Cairns Blue RRS HSE Loaded
Post #159685 Fri Mar 14 2008 3:11am
dukemasterpro
Australia
I'm going on an organised tagalong so recovery gear is not needed, any suggestions on other RRS spares different to below would be very helpful.
Post #159687 Fri Mar 14 2008 6:24am
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
A fire extinguisher, an air jack and ropes. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #159695 Fri Mar 14 2008 8:40am
Mobile phone charger, if you get signal out in them thar mountains.
Post #159699 Fri Mar 14 2008 9:05am
Tim in Scotland
20-50litres of spare fuel,
a full sized spare wheel and tyre
I would also remove the spare from under the car and put it on the roof or in the back - it makes changing a flat so much more pleasant than having to dig it out from the sticky mud you got the flat in! Also while you are under there remove the two wind deflectors from the front of the spare wheel stowage, only to save them from getting ripped off at the first bit of rocky going and also saves you wondering what the hell is getting torn off underneath when if they were still there.
Have you got any aluminium under-body protection plates/ sumpguard fitted? A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #159732 Fri Mar 14 2008 11:00am
dukemasterpro
Australia
RE: sump /underbody protection - NO! but the tip to remove the spare wheel cover sounds a good idea.
Has anyone called Land Rover Assist for off road recovery or problems caused off road? I spoke to a Land Rover specialist ( not a dealer ) and he indicated that due to the complexity of the parts listed to carry as spares it would be better to leave it to LR Assist to get you underway.
Post #160032 Mon Mar 17 2008 8:26am
Pelyma
Autologic system Shocked DS3 TDV6 HSE
Silver with Alpacca
Post #160212 Mon Mar 17 2008 3:56pm
Working Dog
Australia 2008 Range Rover Sport TDV8 SE Chawton White
Laughing Laughing LR assist here in the mountains will be a local NRMA tow-truck back to the closest dealer - I don't believe they are going to be carrying a lot of TDV8 Parts. Just a white TDV8 with a few extras
Post #160319 Mon Mar 17 2008 10:57pm
stephenw
Australia 2007 Range Rover Sport TDV6 SE Stornoway Grey
Try this for suggestions. I put this together a couple of years back. It needs to be tailored to vehicle and location but can be a good memory jogger.
http://www.lrc.org.au/4wdstuff/TripPrep/index.htm
Steve RRS TDV6, Stornoway Grey, Tasmod Sills, Active Rear Diff, AVN 6000 player inc DVD, Sat Nav, TV, Rear Camera and Front/Side Looking Camera, HDD Media Player, Parrot Bluetooth, UHF, Sat Phone, Dual Battery, Rhino Racks, Snorkel, ARB Air Compressor.
Post #160361 Tue Mar 18 2008 10:20am
View user's profile Send private message Send e-mail Reply with quote
dukemasterpro
Australia
Well the trip was a success - the car performed beautifully over sand, gravel, rocks and everything in between over 4 days of very steep and rutted driving in the New South Wales and Victoria High Country.
And the 19" rims and rubber are exactly as they were when we left! ( thank goodness for no damage or punctures! )
Will post a few action shots and trip detail later!
Post #161380 Tue Mar 25 2008 9:23am
tastech
Australia 2008 Range Rover Sport TDV6 SE Rimini Red
So Duke what equipment did you or others find yourself reaching for???
in other words what would you not leave home with out
Post #161580 Wed Mar 26 2008 5:17am
dukemasterpro
Australia
Well - asides from a good supply of snacks to eat at smoko, a thermos for hot water and warm clothes it was a pretty safe trip. Next time would prefer some proper off road tyres instead of praying that the 19" wranglerss would not get punctured on a rocky climb or rim damage ( none luckily ). Does anyone remember who had those 17 or 18" rims for sale?
It was good to discover that the other drivers ( in Toyota's and Pajero's ) could also not buy spares like bottom radiater hoses ( 6-8 weeks from UK on back order from LR ). The best suggestion I heard for building a spares kit is to ask for any old parts when new ones are fitted - eg fan belts, drive belts, filters etc. These may have done the miles but could get you out of difficulty if needed.
We also had a great "bush mechanic" with us, Wayne from Great Divide Tours and I think had the worst came to the worst he could have done a decent enough trail repair.
There was nothing that we brought that was out of the ordinary. The only thing needed was some cable ties to reattach the panel located mid way along under the car ( it's secured by 2 plastic bolts ). This got caught on a few of the larger conservation mounds / water bars on our trip.
For a future trip am looking at getting OZICOZI fitted ( it's a clear film to protect paint ) any forum members got this or had experience?
Post #162314 Sat Mar 29 2008 1:36am
You mean the Compomotive ones?
Post #162613 Mon Mar 31 2008 11:38am
Working Dog
Hey DMP,
You might want to check first, if your TDV8 is the same as mine, you will have the Brembos fitted, which means that you may be limited to the 19" wheels that you have on there or larger, unless you want to go through some modifications.
See this thread http://www.rrsport.co.uk/forum/topic6515.html Just a white TDV8 with a few extras
Post #162873 Mon Mar 31 2008 8:47pm
