Home > Technical > Be aware...Space saver spare wheel and Transmission problems
Jonty
United Kingdom 2005 Range Rover Sport TDV6 SE Zambezi Silver
Hi All
Apologies if this information is posted somewhere else on the site but I couldn't find it so thought I'd pass on something I stumbled across yesterday.
After an unfortunate misunderstanding between my front tyre and a metal spike I was forced to use the space saver spare tyre. After fitting the tyre the Auto transmission would only go up to 3rd gear and then stop changing up. If I manually took control of the gears it worked fine and went all the way up to 6th.
Fearing the worst I got the car into the dealer (who didn't believe what I was telling them until they took it for a test drive). They called LR to be told that the space saver wheel / tyre is a different circumference to the normal wheels and tyres and that this was upsetting the transmission ecu. Dealer fitted a normal sport wheel and did another road test. Hey Presto! everything works fine.....
Please bear in mind if you ave to resort to the horrible biscuit spare tyre....
Post #159302 Wed Mar 12 2008 10:49am
Yep, you only used to get a 19" spare even if your car had 20s from the factory not sure if that's still the case.
Post #159304 Wed Mar 12 2008 10:51am
Tim in Scotland
It is as my car has not only a 19" space saver, but it is black! It thought that you were only supposed to be able to drive for 50 miles and at 50mph on a space saver - which would be another reason why the car wouldn't go into 6th as well! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
TDv8 HSE - Stornoway Grey with ebony and straight grain walnut wood-a-like interior with towpack, Tasmods. The best car I have ever owned
Now departed - Giverny Green TDv6SE with Aspen and Parchment interior - nearly the best car I have ever owned
Staying - Epsom Green Defender 90 for playing off road
Last edited by Tim in Scotland on Wed Mar 12 2008 10:59am. Edited 2 times in total
Post #159307 Wed Mar 12 2008 10:57am
Yeah, mine was black... and had the yellow warning stickers on it saying just that.
Post #159308 Wed Mar 12 2008 10:58am
Tim in Scotland
My answer above conflicts with the reply I made on the thread about the painted stormers..................... LR do supply coloured wheels - black space savers! Embarassed Embarassed A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #159309 Wed Mar 12 2008 11:00am
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
The space saver is a pain - do as I have done and buy a full size spare from ebay. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #159310 Wed Mar 12 2008 11:02am
Tim in Scotland
Yeh that's fine if your normal tyre is a 19", but a 20" spare has to travel in the boot or on the roof as it won't fit in the spare stowage well under the car! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #159311 Wed Mar 12 2008 11:04am
I thought it has been proven that a 20 inch does fit below. I stand to be corrected. I have a 19 with an MTR on which is larger than your normal tyres and that fits. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #159312 Wed Mar 12 2008 11:06am
Tim in Scotland
I will have to check then VA, I haven't tried I must admit - I don't have a spare 20" lying around to do the test! I'm just going on what I was told. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #159314 Wed Mar 12 2008 11:08am
I too thought a 20" spare wouldn't fit in the well, but again never tried it.
Post #159318 Wed Mar 12 2008 11:11am
Charles Hurst Park Royal
Site Sponsor
Will try and report back soon! Thumbs Up Paul King - Service Manager paulking@charleshurstgroup.co.uk
Andy Harding - Parts Manager andrewharding@charleshurstgroup.co.uk
Please mention "RRSPORT.CO.UK" when enquiring!
Charles Hurst Land Rover - Park Royal
152 Dukes Road
London
W3 0SL
0208 992 2299 www.charleshurstlondon.co.uk
Post #159325 Wed Mar 12 2008 12:20pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Actualy the 19" space saver is GREATER in diameter than the 20" with the conti. I measured them up back when I was getting the 19" with the MTRs on and the 255/55 R19 MT/R is 30mm bigger in diameter than the 275/40 R20 conti and it fits in the spare wheel well no problem, it is what is on the car at the moment.
Edit:
Also I noticed on the load rating for the black "space saver" that it was rated to a higher weight than the 20" 10 spokes that LR put on the car.
Just checked what is in the garage
Black sace saver Max load 940kg 255/50 R19 cross contact 73cm dia
5 V spoke 19" Max load 900kg 255/55 R19 MT/R 78cm dia Sons of dogs come eat flesh
Clan Cameron
Post #159330 Wed Mar 12 2008 12:53pm
Site Sponsor
VA and Alicatt are spot on, 20" wheel does indeed fit! Thumbs Up Paul King - Service Manager paulking@charleshurstgroup.co.uk
152 Dukes Road
London
W3 0SL
Last edited by Charles Hurst Park Royal on Wed Mar 12 2008 1:38pm. Edited 1 time in total
Post #159358 Wed Mar 12 2008 1:36pm
Excuse me but I thought I said it fitted! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #159360 Wed Mar 12 2008 1:38pm
Tim in Scotland
OK so it fits - now to find one to replace my space saver! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #159376 Wed Mar 12 2008 3:00pm
