Home > Maintenance & Modifications > Water in headlight
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Water in headlight
I have somehow got a fair bit of water in my 2 headlights. I have taken the units off and see that they are not water tight. I have drained as much as possible and hope that the heat of the lights will evaporate the remaining water. Has anyone else had this issue? RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #158166 Tue Mar 04 2008 7:32pm
Tim in Scotland
No, haven't taken either of my RRS's into water deep enough to wash off the bonnet................................ try putting them in an oven at a VERY low setting (otherwise you get smoked lenses!) or leaving them in the airing cupboard overnight, make sure that any vent holes are on the top though so the water vapour can get out. Hope this helps. Does VA Towers have an Aga? That is the best place to dry them out overnight - on a rack above the Aga.
VA one thing to what out for after the dunking is the heat/sound deadening material under the bonnet, when I waded my 90 in water up over the bonnet the sound deadening absorbed a lot of water and then it hung down onto the cambox of the engine and in the near to the turbo......................... had to do some drastic surgery to the material to stop it from catching fire with the engine/ turbo heat. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #158169 Tue Mar 04 2008 7:41pm
modbarra
United Kingdom 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Had fair amount of water in one headlight following outing at Yarwell...... took to dealer who replaced under warranty without any hesitation
Post #158241 Wed Mar 05 2008 10:03am
Tim in Scotland
Better get the car into the dealer quick then VA before the warranty runs out! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #158246 Wed Mar 05 2008 10:17am
It's in tomorrow! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #158247 Wed Mar 05 2008 10:17am
Tim in Scotland
Hope they don't consider it "fair wear and tear" ........................ A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #158251 Wed Mar 05 2008 10:29am
They shouldn't - only happened when wading which this car should handle. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #158252 Wed Mar 05 2008 10:31am
bungee
are the headlights not higher that the recomended wading depth Question i am not near my car for the next few days so i cant check the manual
Post #158279 Wed Mar 05 2008 6:01pm
Tim in Scotland
But you get a decent bow wave that will come over the bonnet and be lower than the intake if you go in properly! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #158283 Wed Mar 05 2008 6:04pm
But when you wade you create a bow wave which is higher than the max wading depth. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #158284 Wed Mar 05 2008 6:05pm
bungee
bow wave
when you create a bow wave it is in front of the vehicle ,so should not be able to get in the rear of the headlight the same way as it does not enter the air intake ,if it is entering the headlights this way the headlights are faulty Thumbs Up
Post #158330 Wed Mar 05 2008 7:10pm
Exactly. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #158331 Wed Mar 05 2008 7:12pm
