| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Maintenance & Modifications > Water in headlight |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14728
I have somehow got a fair bit of water in my 2 headlights. I have taken the units off and see that they are not water tight. I have drained as much as possible and hope that the heat of the lights will evaporate the remaining water. Has anyone else had this issue? RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| modbarra Joined: 10 Jan 2008 Location: northampton Posts: 33
Had fair amount of water in one headlight following outing at Yarwell...... took to dealer who replaced under warranty without any hesitation |
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 7508
Better get the car into the dealer quick then VA before the warranty runs out! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
It's in tomorrow! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Hope they don't consider it "fair wear and tear" ........................ A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
They shouldn't - only happened when wading which this car should handle. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| bungee Joined: 17 Aug 2007 Location: a lovely place Posts: 16 |
But you get a decent bow wave that will come over the bonnet and be lower than the intake if you go in properly! A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
But when you wade you create a bow wave which is higher than the max wading depth. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
when you create a bow wave it is in front of the vehicle ,so should not be able to get in the rear of the headlight the same way as it does not enter the air intake ,if it is entering the headlights this way the headlights are faulty |
Exactly. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Staying - Epsom Green Defender 90 for playing off road
