| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Maintenance & Modifications > Hi newcomer here!....got a question about side steps... |
| mambo Joined: 24 Oct 2007 Location: in the mud Posts: 44 |
Side steps can be taken off without any problem, some trim needs to be cut to install mudflaps so they may leave a mark. |
| AJ Joined: 20 Nov 2007 Location: London Posts: 8 |
has anyone else removed these....are any marks visable? is there any chance for water leakage?
| umbertob Joined: 23 Sep 2005 Location: Pasadena, CA Posts: 711
Welcome, AJ. A 4-5" section of rubber moulding around the front wheel arch is cut to get the front mud flaps to fit flush with the body and to screw them on. So, there will be a couple of screw holes left exposed where the rubber moulding used to be after you remove the flaps, no biggie. Here is a picture of mine after I removed the front flaps, you can see the two holes... I had to remove them when I installed my rock sliders, but I have since put them back on after a bit of creative "cutting" of the flaps around the sliders (I couldn't find a close-up shot, sorry):
Thanks for the informative reply....i think i will get the trim/moulding replaced if the situaution arrises and its good to know that i can take off the steps and then put them back on if i change my mind.
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14724
Not sure if its been said before 'white is the new black!' RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| Supertrotter Joined: 10 Mar 2006 Location: Home to the sun, sea and........HUMIDITY! Posts: 7347
Not sure if it's been said before 'ONLY LR OE STEPS WILL DO!' 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods, Black Badge Soon...
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 20265
I don't know it has SuperT? RRS TDV6 Gone but still around
Let me try again |
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1828
