Home > Maintenance & Modifications > Exhaust Tips install issues
BoatMad
Ireland 2007 Range Rover Sport TDV8 HSE Java Black
Fitted the tips from Autochrome
http://cgi.ebay.co.uk/Range-Rover-Sport-Ch...dZViewItem
Only things is the tips touch the swinging weights at the rear and make a nasty vibration noise at tickover ( as well as rubbing).
Any ideas from people who have fitted these I was thinking of getting some stainless steel cable ties and trying to pull th exhaust slightly to remove the contact. RRS HSE TDV8 Java black/Ebony interior, mud flaps,20" stormers, towing, roofrack,sunroof,cooler V8 Tasmods Sills,black badges, carstyling java black vents
Previously FFRR TD6 Metallic Grey
Post #155274 Mon Feb 11 2008 12:06pm
Location: Growing old is mandatory; growing up is optional.
Mate from what i remember fitting mine there was a hook the came off the side of the exhaust back box!
try to tie off of these or try and pull it or a bit from here as well
you'll see it it's held in place but a rubber roll sort of think RRS TDV6 Gone but still around
Shaguar Hard Type (know you all miss her but she's gone)
Oh and i love the girlzzzzzzzzzz!!!
Post #155381 Tue Feb 12 2008 12:08am
Roland
Switzerland
Sorry Jaymann, could you try and explain that again??????? Embarassed
I should get mine shortly and am really concerned SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2006 RRS TDv6 HSE, zermatt-ivory-rhodium with 19" alloys for winter, 20" for summer and stock grille, side vents...
Post #155484 Tue Feb 12 2008 3:14pm
cyberjes
2008 Range Rover Sport TDV8 HSE Buckingham Blue
/Jaymann
i think you are refering the the mounting of the silencer unit of the exhaust but
boatmad is talking about the rattling noise after installing the exhaust.
/Boatmad
i suggest you look where the tip is rubbing against and try to put something to
work as (heat resistant) cushion of some sort.
or, try to relocate the tips so that the rubbing won't occur.
nothing like sorting out a problem with the beloved ride.
good luck. MY08 TDV8 HSE
Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock
Post #155495 Tue Feb 12 2008 5:03pm
BoatMad
Jayman thanks I'll have a look as what I'm trying to do is to pull the whole back exhaust about 4-6mm outboard to move the exhaust tips off the weights. RRS HSE TDV8 Java black/Ebony interior, mud flaps,20" stormers, towing, roofrack,sunroof,cooler V8 Tasmods Sills,black badges, carstyling java black vents
Post #155828 Thu Feb 14 2008 7:36pm
Sorry i didn't have the time to get a pic had something come up Sad RRS TDV6 Gone but still around
Post #155857 Thu Feb 14 2008 11:10pm
