| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > SATNAV and POI |
| 949BFN Joined: 16 Apr 2007 Location: Bloemfontein Posts: 13
Anyone knows if this will work with the RRS system: http://www.pimp-my-nav.com/index.htm (It is an application used to make a copy of the original NAV DVD, adding custom POI (like safety cameras) at the same time.) I suppose the question is actually, does the RRS use the same navigation computer as the FFRR? If not, anyone know of a similar application we can use with the RRS? I have always thought the ability (or actually lack thereof) to add custom POI is the biggest disadvantage of the built in navigation systems. 2007 RR S/C with video and rear view camera system from http://www.tvandnav2go.com/. |
| JGreg1 Joined: 04 Jan 2008 Location: Rogers, Arkansas USA Posts: 40
Interesting. Will be curious to see if that will work with RRS Navi, but I fear not. |
| umbertob Joined: 22 Sep 2005 Location: Pasadena, CA Posts: 738
That won't work. The Denso satnav in use on RRS, 2005+ FFRR and Disco/LR3s is a whole different animal than the one fitted on earlier MY Range Rovers, which used a BMW based satnav shared with most BMWs and Mini. That system was far more "hackable". The new one uses a cryptic file format, making it virtually impossible to crack / modify. |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 20845
That's a sham would be good if you can add your own POI's |
| Martin Site Administrator & Owner Joined: 26 May 2005 Location: Shoreham-by-Sea Posts: 2249
The BMW Nav system is based upon a clear directory structure and uncompressed HTML and text files.
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20671
Someone did once say on here, that they would be putting some of their finest minds onto it... and they no doubt ran into the same problems |
| All times are GMT |
